Posts: 4,970 |
Originally posted by RTStabler51: Originally posted by Swazo: I'm not looking to be any HP/TQ record setter, I just want a usable amount of power.
That's the key, in a FWD platform sure high HP/TQ numbers look good...but is it usable?
Now I'm putting a lot of effort into making my car able to use the power it will be putting down. *H&R Springs(already have) w/ Blistien struts(still need) *SF connectors (GB) *LCA box-in plates (GB) *Shore 94A roll restrictors(already have) *Axels that are snap resistant (Will need ) *GOOD EBC to properly put down the power onhand(still need and am doing my research) *Light weight wheels w/ 235-245 meats(still need)
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 9,065 |
Originally posted by Swazo: Originally posted by RTStabler51: Originally posted by Swazo: I'm not looking to be any HP/TQ record setter, I just want a usable amount of power.
+ new longer studs and 25mm spacers!
Posts: 6,106 |
Why? Unless he's got 13" brakes with wheels that won't clear, I see no reason to add spacers. Why push your wheels out if you don't have to?
Mark
2000 Black CSVT
Posts: 9,065 |
Originally posted by Y2KSVT: Why? Unless he's got 13" brakes with wheels that won't clear, I see no reason to add spacers. Why push your wheels out if you don't have to?
Mark
how is he gonna fit 8" of rubber in those wheel wells!?
Posts: 3,496 |
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: Originally posted by Y2KSVT: Why? Unless he's got 13" brakes with wheels that won't clear, I see no reason to add spacers. Why push your wheels out if you don't have to?
Mark
235's will fit all day long
Posts: 4,970 |
Originally posted by Buckshot77: 245/45/16's here on SSR GT1 rims. I used a 5mm spacer in the rear to clear the struts and then some major fender rolling and trimming to get them fit in the rear. Of course I'm also running on eibachs so undropped cars shouldhave as much problem with rubbing. They tires fit perfectly up front with no spacers.
Posts: 6,106 |
I had some 245/50/16's(drag radials) on the front, on stock E1's  Only had them on a couple of days for when I went to the track. They'd rub on quick turns, and the abs light would come on over 45mph. But I wouldn't think he'd be running that large of a sidewall.  Mark
2000 Black CSVT
Posts: 718 |
Originally posted by Y2KSVT: I had some 245/50/16's(drag radials) on the front, on stock E1's Only had them on a couple of days for when I went to the track. They'd rub on quick turns, and the abs light would come on over 45mph. But I wouldn't think he'd be running that large of a sidewall.
Mark
Still got those tires?
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 6,106 |
I actually was borrowing them from a friend of mine. He had them on his SHO. They're actually perfect fit for a Mustang.
Mark
2000 Black CSVT
Learned patience the hard way
Posts: 2,454 |
I've got a full set of 245/45/16's brand new if anyone is interested in them.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
