Posts: 4,270 |
Originally posted by GI8U2racing: Are these strong enough to attach racing harnesses to?
These are mounted in the trunk so i'm not quite sure how you plan to attach it.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 21,653 |
I would not advise attaching a harness to the RSTB, both because of it's location and how it's usually secured (usually not welded in). You need a bar behind the seats running between the B-pillars if you want a bar, though there are other less permanent ways to install a harness correctly.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,867 |
Originally posted by Kremithefrog: I would not advise attaching a harness to the RSTB, both because of it's location and how it's usually secured (usually not welded in). You need a bar behind the seats running between the B-pillars if you want a bar, though there are other less permanent ways to install a harness correctly.
This bar would not be suitable.
You could use a welded strut bar as a harness bar, but then that would probably break the rules in a lot of classes.
Function before fashion.
'96 Contour SE
Posts: 3,867 |
Originally posted by 5V7 Dr1v3r627: Originally posted by GI8U2racing: Are these strong enough to attach racing harnesses to?
Flip down or remove the rear seat, yo!
'96 Contour SE
Posts: 32 |
Alright, yeah, I agree, one not welded in or super secure like an ST200 would not make sense. I was just kicking ideas around, i'm still interested nonetheless.
Posts: 6,791 |
Alright, got the aluminum on friday... So this should be picking up in progress soon
Posts: 32 |
Alright, well I am definitely in. I was wondering, since it looks like it just keeps tention in the towers by pushing them out, would there be a benefit to putting bolts/nuts through the tower to make sure it never moves or gets loose in a tough turn?
Posts: 7,117 |
Originally posted by GI8U2racing: Alright, well I am definitely in. I was wondering, since it looks like it just keeps tention in the towers by pushing them out, would there be a benefit to putting bolts/nuts through the tower to make sure it never moves or gets loose in a tough turn?
I don't think our towers move THAT much! I had one on my first Contour & ran it hard. No problems with it moving at all, so you should be just fine.
If you don't have enough compression to keep the bar in place, or your towers flex so much that the bar gets loose, then you've got problems a bar will not help and should have you car checked out before it splits in half.
Posts: 1,119 |
so what is the news with this gb? I've been watching it and considering, but I haven't see any updates!
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 6,791 |
Okay heres an update:
The aluminum is in and ready to be tapped. The weather has been slowing us down, ummmm monday or tuesday im picking up some left hand nuts and we should be ready to build after that
