Posts: 3,867 |
Originally posted by todras: Originally posted by RogerB:
ROGER: The high wear metals are not unusual finds in the oil from a new transmission. Lead is coming from marking compound used at the factory, and it should mostly wash out with this oil change or possibly the next one. Copper is left over from new parts wearing in and should also improve nicely with the next oil change. Universal averages show typical wear metals for an oil from this engine after about 20,000 miles use. Insolubles read at 0.1%, which is fine for a manual transmission. No contaminants found. Check back to see improvements.
...a trans oil can only come from one source...the plain bushings that the stoc shft forks slide on.No other component is copper or lead.Lead marking/meshing fluid is not used on the assembly of an MTX,(as opposed to a stoc 'rear end' meshing check)the meshing on an MTX is fixed as the crown wheel,input & output shaft positions are fixed in the cases...FWIW!
...high miles MTX's that have run from day one on ATF has been,in 9 out of 10 cases,that the shift forks are very tight/stiff on the shift rods(Vs a new stoc fork),this leads me to think that long term exposure to ATF fluids causes the lead based shift fork bearings to 'grow' and become tight on the shafts and maybe 'shed' some of the lead during operation when stiff.To take lead and copper out of the MTX is done when I fit slick shift forks,the bearings are all steel roller type....FWIW!!!
Terry? Zat you?
Thanks, Todd. Did Terry see this analysis? I was going to post on his forum, too, but maybe I'll save the drive space.
Function before fashion.
'96 Contour SE
Posts: 21,197 |
At 23 when I bought the car it was the first thing I did when I brought it home. I guess common sense is different from person to person.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,106 |
Originally posted by todras: I guess common sense is different from person to person.
Yes, because common sense to me says that this sentence.......
Originally posted by todras: Their are seperate fill and drail holes
should have started with There
Mark
2000 Black CSVT
Posts: 4,693 |
I also noticed that thing about lead being used to check the gear mesh. Lead hasn't been used for that for at least a couple of decades. Titanium dioxide has been common for a long time. You can't even buy the lead compound for rolling a pattern on a diff anymore. Blackstone needs to revise their comments.
I do believe that Ford has no maintenance interval for changing the manual trans fluid in our cars. I still change it anyway because I want it to last a long time.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 3,867 |
This is true. I have never found any Ford documentation on the subject, and I had a dealer service rep tell me it never needed changing.
Now, think about that. These are the same guys trying to sell me 3k interval motor oil service on a car with a factory-recommended 5k interval. These are not the guys trying to sell me the car. If they are turning down a service opportunity, I just don't get it.
I'm 39, and I think I've changed manual tranny fluid, oh, maybe twice before this (only once I can actually remember). Lots of people overservice their cars because their grandpa's 39 "deuce" needed clearances checked every 1500 miles, and by golly if it worked for him... Anyway, I followed the recommended intervals on my other cars and the trend was that the newer the car, the longer the interval.
On my old CRX, you were supposed to check valve clearances every 15k. I overlooked this service (accidentally) until 45k. Clearances were still tight, and that was on a car from 1989. Based on my experience (common sense?) it was not hard for me to believe that a newer car would have even longer service intervals.
Oh well. You're right sometimes, and you're wrong sometimes, and as I alluded to above, common sense is uncommon (and often conflicting).
'96 Contour SE
Posts: 6,910 |
i agree about the dealers trying to sell you on other parts, like when my mother contour was in for a P0420 CEL and the PCM reprogram they called up and said by milage that it needed an oil change, ps fluid change, accessory belt, and a few other things, best part of that was I had just changed the oil myself ...
but like you said, we ended up doing it ourselves but my father said he would have paid to have the trans fluid changed on our Windstar if the dealer offered as it was a mess he really didn't want to deal with
- 95 Mystique LS - Zetec/5spd
Posts: 3,867 |
No kidding on the Windstar. I enjoy changing oil and all that, but some things life is just too short for.
'96 Contour SE
Posts: 137 |
I don't see why they can't put a drain plug in automatic transmission oil pans. It would be so much nicer if you could drain the oil out of it before you took the pan down to change the filter, instead of trying to undo all of those crazy bolts with out spilling it everywhere.
I am probably going to kill my Aerostar tranny, because I am putting off the mess.
1998 Contour SVT Black w/ Blue interior
Torsen LSD updated shiftforks
Lightened Flywheel, HD Drivelines
Optimized Thottle Body
2003 3.0L engine upgrade (Soon to be)
Posts: 1,177 |
FWIW my dealer's service people told me either 75k or 100k, I forget which, for tranny fluid changes.
1998.5 T-Red on Midnight Blue SVT
Build Number 5320 of 6535
Posts: 5,810 |
Yeah, I was just following the service guide, but my shift forks were so toasted by 25K miles from being so stiff that my shift cable snapped. It never shifted easy after that until I tore it apart and found the problem. Ever since then it's been just like butter, especially on REDLINE!  Shoulda gone with my gut and changed the trans fluid once a year. I do now! BTW So far, I'm loving this Torco RTF for shift feel.
See My Mods
