Originally posted by sleepie1084:
Okay. I know everything on how to do it. I know how to put them in the door handle. My ONLY problem is putting them in the switches that are the window and the lock buttons. I used 5mm leds but they are too big.. I made them fit, but are there some smaller ones?, because I had to do a LOT of work to make them fit. What LEDs did y'all use for the SWITCHES? Not the door handle..
This is for the led's in the switches,
NOT IN THE DOOR HANDLES!!I have done this.
I used 5mm led's in my switches as well. I
DID have to modify the switch to get it to fit back together properly though. Basically all you need to do is to remove the old led and resistor, (if using 5mm led's, cut off the plastic tab thingies that supported the old led -this will give more clearance- and also, I found it necessary to sand down the rounded hump on the led to make it flat, not a whole lot, just enough to flatten out the top.) Then on the underside of the switch button where there is a white plastic piece w/ a square hole in it... I had to use my soldering iron to melt out the hole a little bit larger. Once you have done all that, just make sure you have the new led seated as flat as on the switch body and soldered in the right way, and just snap the top part back on. There are smaller led's out there, but if you are wanting blue, good luck finding some that are bright enough.
hope that helped a little.
