Posts: 4,051 |
Originally posted by Stazi: I have seen some people do it themselves. Some do it well, the others - well, you can see they f'ed it up bad. Y2KSVT gave up after trying to do it himself and ende up sending it to me.
I suggest you all send your ovals to Stazi. I had mine done by him since I didn't want to mess mine up and it came out perfect.
But......I took the oval apart to paint the oval ring black, and even just putting the oval back together how he had it, I screwed it up a little bit. The plastic is too fragile.
Posts: 9,872 |
Stazi any tips for installing the lower mesh and rear?
Posts: 10,015 |
Yes, you line it up and starting from the middle you look where the center tabs touch the mesh. Snip the mesh that is blocking in the top two spots first to make a window for the tabs to go into, and ten push it onto the tabs a little, then look at the bottom two center tabs touch and do the same, then move outwards on both sides, etc. once all tabs are in the mesh, press the mesh forward to but up against the bumper and then take you stock clips form the plastic grills and squeeze them a bit to grip the tabs ad push them on the secure the mesh in place. You'll understand it better when you get the mesh in your hands and put it up against the opening and the tabs. I'll do the windows on the back piece for everyone and then you'll see how to do the front lower piece.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,651 |
Is that the same for the rear?
I reject your reality and substitute my own.
Posts: 36 |
1) Goonz SVT - SVT kit (paid) 2) Arhethia - svt set 3) scottd60 - SVT set 4) GetLucky151 - SVT set 5) akrump47 - SVT set 6) NorthPoleSvt - SVT set 7) 8) 9)
Blk 2000 CSVT
Posts: 9,872 |
stazi you ship mine out yet?
Posts: 626 |
heh, almost forgot about all this since my hard drive went "bleh" stazu just let me know when would be a good day for me to drive up there for you to do my grill, and i'll take the rest home. mondays or tuesdays would work best for me, as those are my days off work, but go by your schedule first.
Posts: 1,423 |
1) Goonz SVT - SVT kit (paid) 2) Arhethia - svt set 3) scottd60 - SVT set (paid) 4) GetLucky151 - SVT set 5) akrump47 - SVT set 6) NorthPoleSvt - SVT set 7) 8) 9)
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 5,621 |
1) Goonz SVT - SVT kit (paid) 2) Arhethia - svt set 3) scottd60 - SVT set (paid) 4) GetLucky151 - SVT set 5) akrump47 - SVT set 6) NorthPoleSvt - SVT set 7) RG - gonna send my new oval next week 8) 9)
Posts: 10,015 |
For those that are ready to send me their oval and money order, please send it to me at:
Attn: Anastazi Sarigiannis SKF Automotive 46815 Port St Plymouth MI 48150
Gooz, I'm sending you grill out tomorrow
Greasey Monkey you Can drop off you oval to me today. Send me a PM and we'll organise the drop-off.
AUSSIE ENDLINKS $70
