Check the wire is snapped onto the plug OK, Scan for codes. I have Motorcraft and Autolites both, because of a misfire problem (carbon tracks). They are equal if double platinums. You may have the same problem, see this:
plugs
Mine tended to misfire in 4th gear 40 MPH 2200 rpm, give it some gas, not floored.
