JasonJ Offline OP
my battery light is flickering weakly at idle and up to around 2k rpm, but once i rev the engine or get moving, it goes away. ive searched and it seems to be the alternator going out - but those were with the engine above 4k rpm. could it be something else?
it COULD be.. sure.
check your cable connections to the battery, and the grounds from the battery to the chassis, and the alternator to the chassis. also check for loose, frayed, or corroded cables, connectors, and terminations.
ALT TEST:
Check your battery voltage, as described in most of the alternator posts. car running, look for 14.0-14.7 or close
BATTERY test:
car off, surface charge removed (turn on interior and headlights for 60 seconds, look for 12.0 or higher.
JasonJ Offline OP
thanks for the info ray. about an hour ago, i was driving and my tach quit working and then all my interior electronics(radar detector, cd deck, sirius unit) shut off, but the car was still driveable. then gas light came on and the car started to sputter like crazy (im assuming this is where the gas pump cut off) and now the car is completely dead. is this enough info to safely assume that the alternator is shot?
9
yes
Originally posted by LUCA:
Yep. You can be Phil too if you'd like.
F
F
Or alternator wiring, causing lack of charge to battery.
JasonJ Offline OP
right on, it's in the shop as we speak.....
2
You may have a bad diode in the alternator.
Yup. Bad rectifier bridge. I also have the same problem.
Is my car for sale? PM me if you're in South FL.
Originally posted by XKontour98:
Haha that's awesome! Go GM!
YES, SIR!!! General Aviation is Looking good right now...http://www.beapilot.com
