Chrisjd Offline OP
I have dremeled my A6 sidemarkers to fit my car, now i have no idea how to hook them into the turn signals. where is the wire i need in the fender to tap into? How do i go about tapping into this wire? All I want is for them to flash with the signals and maybe parking lights. Please help!
1999 contour se sport- black mtx
-Duratec v6
-dual exhaust
-no resonator
-kkm induction system
-one loud stereo
-35% window tint
-18' Enkei CDR9's on Kumho Ecsta Supras.
-Audi A6 Sidemarkers
(Coming Soon, Very Soon.)
-SVT front and rear bumper.
2002 Passat V6 GLX 4Motion
The wires you need aren't in the fender. They are on the turn signal/parking lamp bulb harness. Unclip it from the bulb in the headlight assembly to access them more easily.
-Louis
1998 Black E0 #3826, lightly modded
I found this on the board a while ago and decided to keep it.
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
H
H
thats an old diagram. trying searching for an updated one. if u want to use the sidemarker as just a turn signal, one ground wire from the sidemarker goes to ground on turnsignal. the other wire goes to turnsignal wire.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
It is old, but the wiring on the Contour hasn't changed. This is the same schematic I used to wire my Audi A6 Sidemarkers. You are correct about the wiring for use of only blinkers, but the diagram above makes the more complex wiring of "on with blinkers/dim with parking lights" a whole lot simpler. You can use different resistance values to change how bright the sidemarkers are when the parking lights are on. The smaller the resistance, the brighter the sidemarkers will be. This does not affect how bright the sidemarkers will be when the turn signal is on.
2000 Contour 2.5L ATX (Medium Steel Blue)
Items for Sale
  • SVT Indiglo Guages (NEW)
  • Traction Control/Rear Defrost Switch (NEW)
  • V6 Speedometer/Guage Cluster w/ Tach (51k miles)
One thing I failed to add in the Original How-To. FWIW, this doesn't affect anything adversely, just another thing to add if you want.
You can put another diode on the same wire as the resistors, between the bulb and the resistor. This will allow the sidemarker to be a tad brighter when the turn signal is on. Some may notice a difference and some may not.
Entirely up to you.
John
jcaimhigher@ixpres.com
Pull out the headlight and just match the wires in the diagram. Go to K-mart or any autoparts store and buy some of those little red slice connector thingys. Go to Radio Shack and buy what you need from there. Throw it all together and your set. The first set of relays I made I didnt solder, but I had the parking lights on and burned one of them out, So the second set I soldered right and theyre a lot nicer now.
If your not sure on how to make the relays E-mail me @ bk4293@aol.com or send me a PM, or post here or do all 3. I'll go to radio shack and get the stuff you need and throw them together, and you just send me whatever I spend. I've already got solder and soldering iron, so I'd say around $10.00 plus shipping and handling, I'll even send reciepts if you like. I aceept Paypal, Money Order, Checks, Cash, Food Stamps, Or Link Cards smile
This is the diagram I used for mine and they look great. Oh wait, there is one catch. Once you get them on, you have to post pics. smile
BLUE-1999 Contour SE-Zetec-Clear Corner Lights-Nokya 3157 corner bulbs-Kenwood Exelon X815-2-12" Pioneers-4 6x8 3-way pioneers-Cuzo 9006's & 9005's-Glowing Ford Emblem On Decklid-Blue Interior lights-Alarm W/ Remote Starter-
Daytime Running Lights-CTA Intake-Winshiel Nozzle Lights-Audi A6 Side Marker Lights-Mesh Grilles (Good Ole Gutter Guard)-Just Added SVT Exaust
Thanks For The Idea CEG'ers !!!
I have never used resistors. Just wired them into the turn signals. Been like this for over a year. laugh
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
