Posts: 3,065 |
Tyler... another note as well. When putting the adhesive on, you need to make sure that none of it goes where any light transmitence will be, or you will get blotchy spots. Therefore, I reccomend something heavier, not a spray can. I used 3M emblem adhesive... it is heavy, doesn't run, and is easy to direct. If you want me to type a full how-to, using your info (w/ the t-bird stuff replaced by contour stuff), let me know or shoot me a PM, I'd be glad to help out.
Posts: 3,816 |
Originally posted by Goonz SVT: will the stock dimming work with these gauges?
Yes
Posts: 128 |
Originally posted by G�¨t�£uck�¥151: so just to refresh since im having a bum night... what comes in this kit? and what do we have to replace with our gauges?
It seems the post I made this morning didnt show up
Anyway, Your gauges, and usually instructions, but since I didnt have instructions for this model there are none, usually the helpful install tips such as the "chroming process" and adding a bulb, the "chroming process" is in this thread, and I did put the add a bulb how to in the packages.
MattR ill be in touch if I need some help.
Yes as you keep your stock lighting, Dont forget you can upgrade your bulbs also.
Tyler
Tyler
Posts: 1,578 |
Originally posted by lizard: so how far off will my mph be since im switching from a se 130mph to a svt 160mph cluster and how can i fix it so mph is right? thanks
It will be WAY off and no you can't fix it, or at least not worth the hassle. Buy a 98.5 or newer SVT cluster and do it that way
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 4,051 |
Originally posted by 98_HO_Contour: Originally posted by lizard: so how far off will my mph be since im switching from a se 130mph to a svt 160mph cluster and how can i fix it so mph is right? thanks
Assuming he actually meant cluster, he'll be fine with the 160 mph.
Posts: 1,578 |
Originally posted by CSVT1214: Originally posted by 98_HO_Contour: Originally posted by lizard: so how far off will my mph be since im switching from a se 130mph to a svt 160mph cluster and how can i fix it so mph is right? thanks
Sorry, read it wrong
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
149 HP @5900
148 LB FT @4300
Posts: 451 |
so will my MPH be off that just confused me
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 4,051 |
Originally posted by lizard: so will my MPH be off that just confused me
Do you have an SVT gauge cluster or not?
I'm not asking what overlays you ordered.
Posts: 451 |
i have an 2000 Se so no but i ordered svt cluster and i just want to kno if it will be off
2000 contour V6 ATX
Posts: 4,051 |
Ordered a "cluster" from where?
If you are talking about the gauges from this group buy, then that was not smart at all. The speedometer is going to be useless to you.
