Posts: 23 |
need help, my car will not get to a very high rpm(ever). i've check all feul,lines,filter,pump,shut-off switch,plugs,plug wires,cylinders,reset computer,exhaust,cat convertor,air flow sensor, also many other sensors. also my check engine light will not go off. i've went to my ford dealer, all they do is reset my computer. it works for like maybe 1 drive or so. took it to many mechanics, they don't know. also been to autozone and hooked up a computer. nothing seems to work. always changed oil, car never smoked, changed filters, everything. car is very well kept up. help needed.TTTTHHHHAAAANNNNKKKKSSSS
1999 Ford Contour SE
2006 Bruteforce 750 4x4
Posts: 6,910 |
get and post the exact code for the cel and someone will help you from there
- 95 Mystique LS - Zetec/5spd
Posts: 1,118 |
Originally posted by brutepower2006: my car will not get to a very high rpm(ever).
thats the rev limiter...and its there for a reason ![](/ubbthreads/images/graemlins/rolleyes.gif)
exactly what rpm is it stoping at?
kevin m
98 T-red mystique gs
zetec ATX
| my ride |
Posts: 23 |
99 se 4cyl dont have rpm gauges but the car runs perfect @ maybe up to 3000rpm, should be about 7000rpm(limiter)
Posts: 5,143 |
Originally posted by brutepower2006: 99 se 4cyl dont have rpm gauges but the car runs perfect @ maybe up to 3000rpm, should be about 7000rpm(limiter)
If it has an ATX. Then Mashing the gas pedal too the floor will only get you too about 5500-6000 RPM's before it shifts, then less and less in every gear. The ATX is designed to shift then because thats basically the end of the Zetec power band, THOUGH the Rev limiter is set too 6500 RPM's. If you are talking about Revving the engine while in park, it wont rev past 4000RPM's due to the rev limiter. It would help tremendiously if you picked up a cheap aftermarket Tachometer, and told us exactly where the engine gives up and doesnt rev past in the power band.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 23 |
thanx, im in the process of getting a tach also when i start to go, i can only push the petal 1/3 of the way or it wont even hardly try to go,it starts sputterin bad, almost seems to die
Posts: 5,143 |
any check engine lights on? If so, I would go to you're local Advance Auto, or Autozone and have them scan the codes. Then get the codes and post them here, we can give a way better diagnosis from that. A very vague idea from me right now is that you're timing is off. How many miles are on the car? Origional Timing belt?
TEIN H.Tech Springs
Posts: 23 |
yes the check engine light is on. the car has around 78,000 miles on it.
Posts: 261 |
have ya checked the battery? mine was doing that and guess what it was? you got it, THE BATTERY!!! try it, you'll like it, i promise.
-Contour's dead, but is being revived...
Originally posted by CSVT1214: Originally posted by ford zetec2: after than, what do i do with the 98 short shifter? do I place it in there like it is?
Stick it in your butt and rotate.
Posts: 2 |
Could be a in tank filter or pump. Does this behaviour change with fuel level? Mine was okay with a full tank but then it would get worse and worse as the tank got lower and lower. Finally it stalled out consistently with ~ 1/4 tank. It was a fuel pump filter inside the tank and yes on the 99 you gotta take the tank out, the nice little access port under the seat was fine before 99, but not after. I replaced the whole assembly because I never ever wanted to do that again.
