Posts: 14 |
I have had my CSVT for two weeks. Out of no where, the car just won't start. I checked the battery cables and nothing is loose, I made sure the clutch was all the way in, and nothing. I get no noise, the car does not try and turn over, yet all of my lights, dashboard panel, and cd player work fine. Any Ideas???
Posts: 14 |
Not everyone at once.
Posts: 1,029 |
Did you check connections at the starter? It could be loose.
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 143 |
could be ingnition switch problem... i hope not for your case though.
The greatest stealth car ever... CSVT
1998 2.5L V6 MTX
KKM intake with BAT pipe
Magnaflow resonator
other Audio enhancements
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 10,015 |
Originally posted by todras: New starter time.
Yep mine went the same way out of nowhere and it wouldn't even click.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 14 |
Thanks for the information. To the two people who had to replace the starter, what was the cost of parts, then what was the cost of labor? And what type of starter should I get. Thanks a bunch, I guess I have to get it towed to the dealership.
Posts: 21,197 |
Labor? What's that. We do everything outselves on here. That's the point of this forum. Starter is like $60 most likely. Who knows how much a shop would hose you for. It takes an hour on the high side. They'd probably juice you for 2 hours though. When you bring it there they are going to charge you a dianostic fee. They aren't going to listen to what you think the issue is. Look at about $300 total if you don't do it yourself.
-'96 SE MTX 3L
Posts: 2,408 |
Posts: 14 |
What is the PATS light? The only lights that are on when turn the key are the check engine light, and the oil light.
