Page 4 of 6 1 2 3 4 5 6
#1462447 12/19/05 12:45 PM
From what I see here, the problem is not whether the CAT cams can be timed correctly (they can), but how simple/difficult it will be. The stock cam sprockets look to be pressed on the cams with a hydraulic press. Therefore, if you make a mistake when timing them, you'll need to press them off and start all over again. Not a simple job.
If they had been bolted on via multiple keyways, this would be much simpler.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
#1462448 12/19/05 01:38 PM
Exactly. And I bet after pressing them off and on only a couple of times they get so much slop in the sprockets that they'd end up as garbage. I'm still amazed that cat cams didn't sell these WITH sprockets - craziness!
#1462449 12/19/05 01:49 PM
Ask 96-99 SHO owners how great pressed on cam sprockets are.
#1462450 12/19/05 02:02 PM
Y
Y
Have you or Aaron tried contacting CAT Cams about this?
Mark
#1462451 12/19/05 02:11 PM
Not me - personally I would like to see them first hand first to see what we're up against.
#1462452 12/19/05 02:42 PM
I have detailed pics. PM me if you would like them emailed to you
Then: 99 Silver Frost SVT #1919 237hp/219tq All Motor Now: 06 White STI Parts 4 sale
#1462453 12/19/05 03:10 PM
You already posted them!
#1462454 12/19/05 03:46 PM
Thanks for pointing that out....perhaps you would like to tell me to search for them?
The images I was going to send Stazi are higher res ones.
#1462455 12/19/05 08:31 PM
OK so I read a post on the NECO boards and I guess the holes in the CAT cam sprocket backing plates correspond with the single hole on the stock sprocket. Apparently there is a center hole which align the cam lobes like stock, then if you want to adjust the cam timing you rotate the sprocket till it lines up with another hole.
there are like 7 holes or something right, well according to cat cams the very center hole is the closest to stock. you line the white mark on the cam gear with the that hole. both holes on the gear and on the cam will line up. that is how you know where the timing should be. the other holes are for retarding and advancing. if you run the the larger pitch cams like you are supposed to they are 10 degrees for each hole. i ran the smaller so its 8 degrees each hole. i just put them at stock for now to get a base, i may want to play with them later to see if there is any power gain.
__________________
That makes it easy then! Also read another post where a guy pushed a dowl pin in through both holes once he had it set - to ensure the sprocket doesn't move.
Should be good to go then.
If this info (which apparently is in the instructions) had be offered by NVS SVT or timeless - we wouldn't have speculated all this time.
This is for both of you guys!
#1462456 12/19/05 09:02 PM
__________________
It's not in the instructions (there are none). This was all from a NECO member, who explained it to me a month or so again. Also from the pics that I have there are more than 7 holes on the CAT cams. The reason I never posted it is b/c it sounds like someone else did the work for the guy and he didn't know everything to 100% confidence. The last thing I wanted to do was give people the wrong idea. I posted pics of them when I saw them with whatever info came with the cams and I left it to everyone else to draw thier conclusions on how to go about it. Had CAT been more diligent in their installation documentation this would never been an issue, but that is not the case.
These cams are not in my posession, but if I had a set I'm sure I would have had this all worked out myself by now. The problem is when I saw the CAT cams I didn't have a stock type cam to compare it with nor has anyone snapped some pics of the two next to each other. Until then I am less than likely to say it is a simple task.
