Posts: 278 |
What I want to know is who is broadcasting in 1080p? What's the new DVD format displaying in?
Curtis
3L 'Oval Port' 98 Black SVT
180.5HP/178lbft
'03 Black Sport Trac
Posts: 48 |
if u want HD get a vidikron now thats HD but u will be paying for it the best hd picture i have ever seen
Posts: 2,469 |
What in the H.E. double hockey sticks is the difference between 1080i and 1080p!!!!!!!!
Posts: 48 |
1080 = scanlines
1080i = 1080 interlaced
interlaced = displays alternates between drawing the even-numbered lines and the odd-numbered lines of each frame.
1080p = 1080 progressive
progressive = storing or transmitting moving images in which the lines of each frame are drawn in sequence.
Posts: 2,469 |
Kinda like progressive scan dvd's? So the interlace is realy only showing a pic. on every other line? Do i have it right?
Posts: 1,516 |
with interlaced every other line is the previous frame, where with progressive every line is the same frame.
Cameron
98 Black CSVT #2958
Posts: 2,469 |
Originally posted by SVTatGT: with interlaced every other line is the previous frame,
Why would they do that? it seems it would be just as easy to make it progressive.
Posts: 4,220 |
Originally posted by dubkatz: Originally posted by SVTatGT: with interlaced every other line is the previous frame,
Interlaced video was created because it takes less frames to get a smooth-looking moving image, therefore it reduced transmission bandwith. That was very important back in the day. You can only send so much information through the air or through a copper cable.
Nowadays with fiber-optics and ultra-fast DVD players the size of images and the necessary bandwith needed is of less importance.
I believe that Interlaced video stuck around even after the advent of HDTV simply because interlaced is just how we've done TV footage for over 50 years and it was easier to stick with that format and let the TV itself convert it to a progressive image if so desired (although this isn't as good as a signal itself that is progressive).
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 278 |
Originally posted by svt1999: if u want HD get a vidikron now thats HD but u will be paying for it the best hd picture i have ever seen
Vidikron is just another HDTV. I want to know who is producing video in 1080p other than a PC. Is the XBOX360?
Curtis
180.5HP/178lbft
