Page 2 of 2 1 2
I don't understand why anyone with an unmodified car would consider removing the secondary butterflies... the intake was optimzed for the best possible flow during the power band ranges that a stock CSVT would have. The primary and secondary runners have calculated lengths so that impulses of air resonate back to the intake valves just as the valves are opening. The higher the rpm the shorter distance the air needs to travel, hence the secondary runners opening at high rpm's. If you remove the butterflies you now have air flowing through that secondary all the time. Which means you are redirecting air away from the longer runners, which are optimzed for all of your low end power, the most possible air is no longer resonating off of the primary runner. This would result in a decrease in power period. However if you have a modified engine that needs resized runners to optimize your power then maybe removing the secondary butterflies could be a benefit, but you would have to know what you are doing. Personally if I had a engine that was that modified I would just build a new intake all together. Either that or find an existing intake manifold out there that has about the right sized runners and retro fit it onto the engine if possible (ex: 92-95 SHO intake)
-Mike 98 Contour SVT Toreador Red #49 of 6535 Built on 3/25/97 WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower 85 Camaro 1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Your thinking is definitely on the right track & the flow theory is sound. However you are a bit flawed your basis.
The stock manifold setup was designed for a 170HP engine and the fact it would be primarily mated to a slushbox. Also the UIM was a compromise to fit under the stock hood. (It was EH'd for moderate flow improvement and port uniformity for the SVT)
Now about the IMRC. The rpm range of "just the short runners" drops drastically as you improve the efficiency of the engine and attached parts. (i.e. mods) The more modified the engine is beyond the stock 170HP slushbox range the lower the maximum rpm range of the short runners will be. There comes a point where the rpm range of the short runners is below even cruising range. Albeit, like you said, not on the stock engine or one close to stock. This rule of flow dynamics is part of the reason why an SVT has a 400-600rpm lower IMRC point even though the engine has a higher powerband due to the cam change. At a lower RPM point it needs more air then "just the short runners" can supply. That's even considering the bit of flow improvement the EH process added to the short runners.
W
W
Did you know that I'd pop up on this???
I am in agreement except on the sticking point where you imply that the plates have to be removed for performance.
No, not really.
For naturally aspirated performance it is very important to keep the runners operational.
If you increase the airflow requirements for that engine then you need to enlarge your runners accordingly.
Removing them is only a viable option if you are having problems with your system.
Flutter, or coding problems that cause unnecessary opening and closing are important. When my secondaries weren't clean I had issues with the IMRC not being able to open them and it really sucked.
However, after I removed them and properly enlarged and modified them when I went to 3.0 liters of displacement I never had a problem. In fact, they complemented the 3L so well that I would never remove them naturally aspirated! I had them pinned open for testing purposes back when I was having a lot of driveability issuse and it really sucks away the low rpm torque, EVEN with a 3L. For me it turned out to be bad plug wires that were really hurting me.
On top of that, I opened my IMRC box and cleaned it up checked connections, etc. I still use my original in the stock location and it works great! No more sticking secondaries. Less manifold cleanings. Etc.
Wow, should I actually give away my secret for success??
I've explained to you in detail what I have done and you have seen the torque curves from the dyno graphs. You know as well as I do that the torque curve is going to tell you the most about whether your secondaries are helping or hurting. You can't argue that my torque curve wasn't as flat as a table top with very slight, almost non-existent torque drop where the secondaries open.
No, not really.
For starters I never said you "had to" remove the rods & plates for performance. I did say that removing them eliminated the turbulence they cause right before the head inlet. Turbulence like that is always bad.
Your 3L is a perfect example of why to remove them. Your 3L showed NO MORE POWER down low then my 2.5L engine (way back when) that also had an operational IMRC. That means they were of no help to your 21% larger engine because mine had the same power output. (i.e. the short runners limited power, plain & simple. Even with you modifications to the manifolds)
Well outside of maybe a little drivability help when tractoring below 2000rpm. I have one word for that though, "DOWNSHIFT!"
I hate to do this to you Tom but that comment about pinning them is pointless. No @%$#^)$ @$#@ you had issues just pinning them. No surprise there. That's not a valid argument at all in this topic. Then to boot your whole problem was wires... 'nuff said.
Above your power curves. See above. Below the IMRC point they were just like my 2.5L engine. Way back before any real mods too. (just intake, MAF, & exhaust) That's more then enough proof to show the limiting ability of just the short runners.
Face it Tom. You are here again now the same thing I said when we first talked about your numbers. There is no real discernable difference between my, then basic bolt on, 2.5L and your full port & polish high compression 3L below the IMRC point. That itself says volumes more then anything I could ever type.
The IMRC is for drivability only. Something it does quite well on the small 2.5L and is a must for the slushbox. It serves no other valid purpose though. There is just no valid supporting argument otherwise.
It does cause countless other issues though. The performance of the engine without one if infinitely better at ANY THROTTLE POSITION (not limited to WOT ) and any rpm above 3000. (of course a lower rpm range for a well modified engine or any 3L)
W
W
NO way! Lay off the crackpipe!
Of course your engine had high torque in the low range, your primary runners were way smaller than mine AND you were chipped! These aren't equal comparisons and you got lucky on your chip to boot. The smaller runner improved the low end torque, especially when you improved the breathing of your engine. My primary runners were much larger (after I ported them) than they needed to be and ended up costing me some of my potential low-end torque....we both agreed on that. On top of that, the average contour 2.5L SVT did/does not have anywhere near the low-end torque that your 2.5 AND my 3L had.
MEANING...again, you were lucky with your 2.5L and you shouldn't use your engine as an example of a normal or average 2.5L! Yours might have been a factory freak. It is/was not a good example of the challenges that everyone else faces....therefore just remove yourself from this conversation because you never had to deal with what us normal no-low-end-torque challenged people had to deal with anyway!
Stay outta Grown Folks talk son....
Oh yeah you big meany head.
My NA car is still quicker then your turbo car. (either of them actually ) What does that say?
Also that should be "stay out of little kid talk, man" Remember I was the one with low end torque in the 2.5L engine. That's manly.
W
W
Hahahaha! too funny.
Now I gotta get my sorry arse to work today.....someone (else) failed to plan right and I gotta suffer for it.
Page 2 of 2 1 2
