Posts: 135 |
I currently own a 98 V6 se with about 200,000 km. The tranny is probably on its last legs, and Im not 100% sure the engines been kept up with the greatest of care (the car was my dads, my old engine was mint after 270,000 km to bad the tranny wasn't, and i have a witness) Any ways, I have been informed that I can pick up a '04 MPV engine and tranny for a reasonable price, from an MPV that was originally in Japan. From what I've been told they still use a 2.5 V6 there. Can anyone verify this, and if I cant use the engine would I be able to use the trany? If I can use the tranny would I have to make any mods to it in order for it to work ie flashing the PCM, changing sensors, etc. Any thoughts or input would be greatly appreciated. Mike
Posts: 3,570 |
You can't just use any old 2.5L V6 in your contour
Posts: 5,143 |
Originally posted by rkneeshaw3.0: You can't just use any old 2.5L V6 in your contour
Yeah, you are going to need a CD4E ATX transmission and a 2.5L DURATEC. the 2.5 V6 in the MPV is a whole different ball of wax, that engine is completely designed by Mazda, where as the 2.5L V6 in the contour's was designed by Ford, Cosworth, and a little bit of porsche engineering. But. You could use an engine from a Mercury Cougar... and im pretty sure the transmission would fit also.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 70 |
Edmunds
The MPV's 2.5-liter V6 was once used in the Ford Contour. It's quite adequate in a small sedan like the Contour, but it's too small for use in a minivan designed to carry seven people.
The big question is if the tranny is compatible?
96 Mystique Black On Tan V6 MTX Port Matched 01 3L, 2.5L Cams, 2.5" Exhaust Optimized y-pipe, SVT clutch, Superchips, 3L split port LIM, SVT UIM, Intake, Mustang 65mm TB, MSDS Headers. Eibach Pro Kit, Torsen Diff., Ford Racing 17" Wheels.
Posts: 699 |
Uhhhhhh....the MPV uses the Duratec
My Cars
1999 Silver Frost SVT - 80,000km #2603/2760 Aug. 10, 1999.
1996 Mercury Mystique LS V6 MTX - retired @ 323,151km.
1995 Ford Contour V6 MTX-sold @ 214,000km
Posts: 3,570 |
Originally posted by KyleH: Uhhhhhh....the MPV uses the Duratec
in that case, it might work
Posts: 9,065 |
Originally posted by rkneeshaw3.0: Originally posted by KyleH: Uhhhhhh....the MPV uses the Duratec
The motor will work, but why bother getting it shipped from Japan.
Posts: 1,580 |
Originally posted by MapOfTaziFoShoââ??¢: Originally posted by rkneeshaw3.0: Originally posted by KyleH: Uhhhhhh....the MPV uses the Duratec
Just make sure you Overnight it.
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 183 |
98 Black SVT (4210/6535)
93 V6 Powered Protege
Posts: 135 |
For arguements sake, lets say the engine is already in north america. Your saying I should be able to use the engine and tranny? Thanks
