#1457148 12/09/05 10:53 PM
What are the chances of two steering racks failing in the EXACT same place? I replaced my original one because it was leaking from one of the seals, I got a reman one and installed it got everything bolted back together, added fluid and started it up. It leaks from the SAME spot.
I'm wondering if I would be better off just buying a brand new unit from Ford, or trying to get a different rack from Napa? Or maybe even hit up a junk yard.
Another question...Is there some special way to install the rack?
#1457149 12/09/05 11:37 PM
F
F
Where is it leaking? Was it filling up the rubber boot with fluid? You certainly can return the bad rack.
#1457150 12/10/05 12:56 AM
The original was filling up the boots as well as leaking from the seal on the bottom. This one is leaking just from the seal on the bottom.
