Posts: 5,882 |
i put in pole's poly roll resistors. do i still need to install that staboshock?
Posts: 183 |
Its a bobble strut, and yes there are aftermarket ones available.. universal ones, just find one that will work.
98 Black SVT (4210/6535)
93 V6 Powered Protege
Posts: 10,015 |
Originally posted by svt4stv: i put in pole's poly roll resistors. do i still need to install that staboshock?
No - with the Poly RR's the stab-o-crap is rendered useless.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 4,141 |
Originally posted by Stazi: Originally posted by svt4stv: i put in pole's poly roll resistors. do i still need to install that staboshock?
WERD!
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 1,506 |
The poly'd roll resistors (as by pole 120) are the best way to go, but there was also a solid torque strut made by Performance Fords they called a "street link" that replaced and improved over the stock csvt stab-o-shock.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 4,141 |
Originally posted by PDXSVT: The poly'd roll resistors (as by pole 120) are the best way to go, but there was also a solid torque strut made by Performance Fords they called a "street link" that replaced and improved over the stock csvt stab-o-shock.
Just to clarify PF made two versions:
"Street link"
Spherical end link one end, poly bushing on the other.
"Track link"
Two spherical end links.
Totaled 02/12/06
Posts: 710 |
Wasn't someone also making a reinforced/braced rear roll restrictor mount/bracket?
morbid
2000 Contour SVT (black)
Posts: 10,015 |
Originally posted by morbid: Wasn't someone also making a reinforced/braced rear roll restrictor mount/bracket?
Pole120 you dope!
Furthermore I would not be installing a SOLID link between my subframe and aluminum cased trans with that POS torque-link-whatchamacallit - talk about asking for trouble - plus the vibration would be ridiculous.
All you need is one of Pole's poly roll resistors, maybe two if you're adventurous - NO NEED FOR ANYTHING ELSE - END OF STORY!
AUSSIE ENDLINKS $70
Posts: 4,141 |
Thanks Stazi.
Did you ever get a chance to try out the poly LCA's?
Totaled 02/12/06
Posts: 10,015 |
I will be installing them when I do my engine beef-up. No need right now as the car is up for the winter and will only be getting torn-down anyway.
AUSSIE ENDLINKS $70
