Originally posted by CSVT#49:
Wow suprised no one mentioned this... check out your cam sensor and crank sensor. They are located on the drive belt side at the end of the front side cylinder head. Cam is up top pretty easy to see and the crank sensor is down below just to the right of the damper. If these go bad it will do the same thing gauranteed. Typically these sensors should be replaced every 60k miles.
There is usually a CEL code for this but who knows...
For the cam shaft sensor,
Originally posted by chongo:
It will take you 5 minutes.
Unscrew one bolt, pull out sensor, screw in bolt!
The crank shaft sensor is also shown below.
