Page 2 of 2 1 2
#1454072 12/12/05 04:44 AM
I get the feeling this is gonna go on for a while
#1454073 12/12/05 05:47 PM
F
F
Have you bled the brakes to get any air out of the lines?
#1454074 12/12/05 05:55 PM
no, have not. bled them when I changed calipers last year. But it is easy and will consider this after I jack up the car today and check for drag on the wheels. You know how cold it is outside today? I don't have a garage, either. I may need some warm scotch after this.
#1454075 12/12/05 05:56 PM
F
F
Yes, it's too cold for car repair in NY state, too.
#1454076 12/12/05 08:17 PM
I'm outa scotch...I'm a bit grouchy now.
#1454077 12/12/05 08:43 PM
The transisiton of it pulling from one side to the next when driving normally and then braking sounds like the A-arm bushings are toast on one or both sides of the front of the car.
#1454078 12/14/05 01:07 AM
ahhh....there we go now! I took it in today and waddya know...bushing and a tie rod end. Brakes work fine.
Stazi has the prize!
#1454079 12/14/05 01:15 AM
F
F
I never thought of that, I'm glad your shop found the problem!
#1454080 12/14/05 02:10 PM
#1454081 12/15/05 03:53 PM
OK....so now that I have the car back I'm grouchy cauz we got one problem (bushing and tie rod end)licked but still have a braking problem in that it is pulling to the right when braking.
Oh....I was just friggin happy...grrr..grrrrr....why does it have to be cold and snowy when I need to work on the car??? GRRRR!!! What I really need is a house with a garage....grrr....grrrrrr
So now I will swap pads, scuff the drivers rotor and bleed lines to see if these are contributing to the problem.
So far we have eliminated 2 suspension probs, slider pins and pistons.
But it's so cold outside....
Page 2 of 2 1 2
