Posts: 2,794 |
OK what do I do? My tacho is real sluggish (if it works).....
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 107 |
The needle's probably sticking against the dials. Either make sure the dials are held down well, or pull the needle up a little (carefully) to give it some clearance.
'93 16V Mondeo saloon Full factory RS setup lowered on 17s K+N 57i, splitfire leads, chipped, full aluminised twin-exit exhaust Sounds by Alpine, Infinity, Vibe, JBL First Mondeo with indiglo gauges
Posts: 2,794 |
what is best way to hold guages down? I am not gonna mess with needles
Posts: 2,794 |
and are the rest of my guages gonna act slow too?
Posts: 653 |
They'll only be sluggish if they rub on the new guages. I used a little dab of superglue around the edge's to hold it down. Works great, although I did have to pull up on the tach just a little. Don't they look great at night? especially the blue. beautiful, simply beautiful Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 2,794 |
Mike, I just started doing them after a3 hr drive home from work...someone flipped on the eway and stuff....I wil let ya know tomorrow....superglue it is....thanks (just too stressed to be doing "gentle" stuff)
Posts: 653 |
Brad Noon suggested tape around the edge's just in case they need to come off. I used superglue cause after screwing up models for the last ten years, i thought i might have finally learned something.
Yeah, just be gentle with the glue Good luck Mike
Posts: 2,906 |
i tooooooooooooooooooold you they are sw33t as hell just went and strutted them at redline meet
Spattmobili®
Posts: 2,794 |
You told me after I posted so it does not count ChiaSpatt......
Administrator
Administrator
Posts: 5,037 |
I know when I get my "rev #2" indiglos I am removing the stock faces to make sure this doesn't happen. Maybe pull the tach needle out a mm or so?
