Page 2 of 2 1 2
Cleaning IAC valves is usually an exercise in futility. Seldom works.
A surging idle is due to an uncontrolled vacuum leak. The IAC is a computer controlled vacuum "leak". When it fails, it often either sticks or overshoots its commanded position.
If there is no evidence of any other vacuum leak, then the IAC is the most likely reason.
Steve
Jimmer, I also suspect a vac leak.
Check the condition of the rigid tubing that runs across the top of the manifold & the elbow connectors at the end. Make sure they're in good shape. Find any cracks, then replace or otherwise repair.
Under the upper intake manifold, just behind the throttle body, you will find a nipple pointing straight down to the engine. There should be a rubber hose connected to it. Make sure it is in place. It fit rather loosely on my first Contour.
Check the hoses that attach to the accordian tube of your intake assembly. The one at the front of the car runs past the water pump pully & belt. Check it for damage/cracks. You'll need to remove the front plastic cover for full inspection of the hose, but that is 3 bolts & easy to do. Follow & inspect the other hoses carefully also.
There are also several rigid vac tubes located near the fire wall. If the other intake hoses are OK, take a look at these to make sure they're in good shape.
Finally, one thing that has been common when the weather turns cold... The intake manifold gaskets start leaking as the aluminum manifolds contract a bit more. Snug them down a bit, but be CAREFUL. They are anchored in aluminum - don't strip them babies!
All I can think of for now...
Also, in future, if you want to test if your MAF is faulty, simply unplug it. If the car suddenly runs smoothly, your MAF was at fault. If the car still runs like crap, the problem is elsewhere most likely.
2
When you unplug the MAF the engine goes into open loop and runs a predetermined rich mixture. It is also open loop when starting cold.
Same problem last year with mine in cold weather. I put it in a warm garage for about 6 hours and she came back around and I didn't have a problem the rest of winter. The problem is back this year but I don't have a nice warm garage
Plain Jane 2000 Contour SE Duratec V-6
For both Jimmer and Thomas Brown. Do the "throttle hang" fix first before you send it to the dealer.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=3
Page 2 of 2 1 2
