Posts: 5,810 |
Originally posted by TourDeForce: Originally posted by MapOfTaziFoShoââ??¢: Eveyone uses the 2.5 valve covers.
Really?? I've never built a 3L, but I would have been inclined to utilize the covers that came with whatever head I was using. Learn sup'm new every day...
You can use the 3L covers from the escape but bolting down the coil pack and IMRC becomes a problem because they use coil on plug and no imrc. Clearance for them is essentially the same. If you have no IMRC and you remote mount your IMRC and coil pack or make a bracket then you can run them.
See My Mods
Posts: 344 |
Heh, that 2.5L upper intake doesn't fit too well on your Noble 3.0L does it, Gabriel? (The 2 blue fittings at the rear of the RH head to feed oil to the turbos are the giveaway)
Posts: 316 |
Originally posted by procyon: Heh, that 2.5L upper intake doesn't fit too well on your Noble 3.0L does it, Gabriel? (The 2 blue fittings at the rear of the RH head to feed oil to the turbos are the giveaway)
Nope, doesn't fit well at all yet.
Man, parts are a pain to find.
Posts: 10,015 |
Gabriel - why don't you use a set of Contour valve covers?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 316 |
I think that's the current plan. We're trying to figure out piece by piece what Noble has changed and what hasn't been changed.
Posts: 4,639 |
Originally posted by gotapex: I think that's the current plan. We're trying to figure out piece by piece what Noble has changed and what hasn't been changed.
why r u trying to figure it out? r u modding the engine? or do u have to assemble it from noble?
Hugo AIM:omegazodiac
