Posts: 1,508 |
I noticed a flickering battery light above 6500 RPM for a while and Thursday the light came on and stayed on. So, I was on my way to Autozone to get the Alternator tested on Saturday and the car died!!  First the Tach went to zero, then the radio shut off and then the speedo went to 0. Then the fuel pump shut off.  Then I called AAA.  That is what I get for waiting. Happy Holiday's!!!!!
1998.5 E1 SVT Contour #5482/6535
Smurfette
Smurfette
Posts: 8,770 |
Kim
1995 Contour GL
Needs less "needs more"
Posts: 6,910 |
thats better then a sudden rear mail seal leak  I think anyway, have to double check ... maybe it will be time for a new clutch also, get it all done at once
- 95 Mystique LS - Zetec/5spd
Posts: 1,831 |
Time for a new alternator. Isn't it fun during the shut-down process. First the radio, then the gauges, then the engine starts to shut down. Ugh. Hope your repair bill is cheaper than mine was at the stealership.
Doug
2006 Mercury Milan V6 Premier Dark Blue Pearl
Former owner of a 2000 SVT Contour
Posts: 7,431 |
One of my friends had an alternator fail in her Subaru while she was on 290 in the left lane at night ... scary!
Posts: 1,508 |
Originally posted by CueballSVT: Time for a new alternator. Isn't it fun during the shut-down process. First the radio, then the gauges, then the engine starts to shut down. Ugh. Hope your repair bill is cheaper than mine was at the stealership.
How Much? Send a PM if you do not want to share with everyone.
Posts: 1,201 |
Its a couple hundred bucks for parts and install. My SVT ate three alts.
Posts: 1,831 |
I don't mind sharing - the part alone (motorcraft) was a little over $200 and install was about another $200. I was in a pinch and they did it the NEXT DAY, so I can't complain. Its only money.
Doug
Posts: 8,445 |
d@mn...i knew i should have charged labor for the 3 alternators i put in that mystique!
i would do it for you ed, but you is a little far away, and i doubt the car would make it to my place.
plus you probably got it done already.
or if you really want, i can come to you and do it.
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 1,508 |
Originally posted by ElKy: d@mn...i knew i should have charged labor for the 3 alternators i put in that mystique!
Thanks Mike. I am having it done at the dealer today. I took a look at it on Sunday and said to myself "No Way" If I had a lift I might think about it.
The car will run for about 5 minutes. So it would take me about 1 week to drive to your house....
