Posts: 3,562 |
Originally posted by Pollo_loco69: Thanks for the info Brad. Question for you....do you happen to know how to make a V6 gauge cluster work for those of us with a Zetec? All I can find around here are the V6 clusters. Someone posted the resistor value needed to change the readings for a V6 tach to work with the 4 banger... Let me go see if I can find it in the FAQ...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 9,178 |
Thanks Brad. I hear that if I don't change things on the gauge cluster it will kill my cruise control too.
Posts: 2,657 |
I told you that once before!!...the resistor and diode will need to be changed out for the tach to read correctly. Maybe if you'd actually READ my emails...and again... :rolleyes: Since your car is a 99 as long as you get a 98.5+ cluster you should be just fine...re cruise control. Its the difference between the 98 and 98.5 clusters that causes a problem with the Cruise Control. Even at that it's probably just a wire in the wrong location.......newbie. :p
Posts: 9,178 |
All right ASS MASTER!  If you can find me a 98.5+ one in Colorado would you do so? I don't know if it is worth it dicking around with the 97 one.
Posts: 2,657 |
I'M WORKING ON IT!!!!!!!!!!!!!!
Do you car if its a V6 cluster?
I got the last one at the yard I go to.
BTW, Please refrain from using bad language on this public forum....butt pirate.
Posts: 9,178 |
I don't care if it is a V6 one or not. Just as long as it works.  Thanks for looking.  If you get one I will get it from you in Vegas and give you some cash.  Let me know how much it runs. I have seen them run here in Utah for about $40-45
Posts: 2,657 |
Well, mine was $65 so yours should be about the same...unless I can steal it.  ...not that I'd ever do that.
Posts: 9,178 |
Let me know.  Now I am excited.  I will have to order the indiglo gauges too.
Posts: 1,075 |
Brad, the interest is there...Or at least it's here. :p
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
