Page 3 of 3 1 2 3
W
W
Originally posted by Stazi:
The Apexi Turbo Timer doesn't datalog. I do have a different datalogger though that taps into the OBD2 port - so that is a problem as I wouldn't be able to do both at the same time.....or could I?
Yes. It will run a narrow band sensor output, a wideband sensor output, AND has the serial datalink output for datalogging all at the same time.
I told you, $200 will be well spent on a proven product like this.
I've had the LM-1 unit about 2 years now. Installed and flawlessly functioning for all of those 2 years as well.
It is an excellent unit that has many capabilities that other units do not have. The completely computer programmable inputs and outputs make it bar none the best datalogging unit for the money.
RyeLou Offline OP
Ryan who/where is this Rob guy and do you have any more info on his Wideband Kit?
Seems as though you're sold on the Innovative unit now, but I'll pass along what I know either way.
His name is Rob. Hes a guy I've met a handful of times now from a Michigan SRTs website. He owns and operates the company from that webpage. He designed the downpipe I have, blah blah blah. Anyhow, he lives out by where Brian used to live (696/94 area). The only info I have about that wideband kit is whats on his website. I do know that what he offers is a great price, and I know he had a few used ones last time I talked to him too. I'm sure you could find something from the manufacturer page. Very nice looking LCD display though. Let me know if you change your mind.
'03 SRT-4 50 trim turbo + support
Greg,
Does the LM-1 log the A/F against another variable, like RPM - or do you need the AuxBox for that? Does it just log the A/F against time?
W
W
Since greg is lazy, I'll answer for you.
The LM-1, meaning the handheld box logs against time unless you build a little signal to voltage converter. Greg did build one of these so he gets both.
If you want to use an LC-1 and don't have an added datalogger, then you will want to build something to provide RPM as well as the air fuel data. The LC-1 uses a DB9 pin seral connector and only the serial port send and recieve to log from the LC-1. You would have to build a datalink to log rpm though there are enough circuits on the web that you could copy if you have any electrical digital circuit experience.
With the LM1 you can log it versus as many sensors as you want up to whatever the maximum is. For tuning multiple cars, the LM-1 is the best way to go and probably worth the investment for as many cars as you play with if you felt like getting into tuning. You just need to tap as many sensors as you find necessary and feed them into the custom cable you will build for your LM1. THe RPM is the tricky one because it uses a frequency instead of a varying voltage. You have to make a frequency to voltage converter. THe other sensors you just can tap into in some cases.
****Sorry if it sounds complicated, it really isn't though. hope this helps****
Just FYI, this Basically is what Wayne of Hypillauto does. He uses an SCT Pro package (Dealer setup) and an LC-1 wired into it to tune and datalogg ford cars and sell tunes and chips.
I also saw a pair of dudes that did mobile tuning service go through texas. THey just called up performance shops as they drove around and set up appointments for the shops' customers that the shop didn't know how to tune. After they pretty much milked the local area of for people needing tunes, they drove off to another area.
Kind of a cool way to make money, Drive around in a Fast Mod'd car and earn your living working on them too. Actually they charged a lot of money too, like $50 an hour or so IIRC.
Armed with just an LM-1 I can tune any car that has an Apex-I or add on type of fuel computer. If the owner possesses tuning software it becomes easier. Something like the emanage allows a significant amount of tuning and those are quite popular in the import world.
With the SCT pro package (if I convert to dealer software) I can handle quite a few Fords too.
Ok so the software with the LC-1 does NOT have a datalogging function at all?
If not - that sucks!
I would think that with the LC-1 connected to your laptop you could do what the LM-1 does, and log against time. Is not the signal to the standard tach a voltage signal or is it a frequency signal also?
Frequency Signal
I also believe the LC-1 does datalogging vs. time
Widebands are the most usefull when you can tie them into your other datalogging software anyway...
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift" "They have diarrhea of the mouth, and constipation of thought"
W
W
Yes, the LC-1 dataloggs just like the LM-1 when using a laptop. The software can accept up to 5 additional inputs on top of the A/F input. It is very powerfull.
The signal is a frequency both to the pcm and to the tach.
Lookup the LM2907 or LM2907n. Those are TTL logic chips that convert frequency to a voltage with a simple circuit. You can look up a sample circuit for them from a chipmaker website and build your converter with simple parts from radio shack in about a half an hour. The total parts, including a hobby box would be less than $10. THe chips run about 50 cents to a dollar each.
RyeLou Offline OP
Theres a GB for the XD-1 on the SRT Forums I just found. Its been there since the 15th of Nov. and ends the 15th of Dec, so only a few days. The deal is $350 shipped as opposed to the normal $390 + shipping. I'm thinking of getting in on it. I like the XD-1 by far the most. And I trust Innovative.
Page 3 of 3 1 2 3
