Posts: 1,119 |
Pic 1
Pic 2
I never noticed how dirty it was there, but how does it look?
Edit: I don't think it is the compressor, although the noise gets worse when it is running.
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 1,119 |
No one has commented on my pictures I provided. so I figured I'd bump up the thread and see if anyone has anything to say.
I'm thinking of maybe replacing the idle pully and tensioner pulley. How hard is this to do, and while i'm at it should I replace the belt?
Trubendz Exhaust
Custom Hood
Posts: 1,505 |
Originally posted by Ray: Simple test... disconnect the serpantine belt.. start the car. Noise gone?
there's your problem.. belt/pulley/tensioners. still there? look elsewhere. a 3/8 breaker bar will loosen the tensioner enough to slip the belt off of a pulley.
do what he said up above. i had to by pass my belt for the ac pump cause it was grinding. you may have the same problem like i did.
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 6 |
Originally posted by ZeroHour: No one has commented on my pictures I provided. so I figured I'd bump up the thread and see if anyone has anything to say.
I have a 97 2.5L and just recently had a similar problem, I checked the local parts houses for my idler pulley, but all were incorrect. I ultimately got it at Ford, for $20, and it took care of my trouble. Use a 3/8 breaker bar to release the belt tension from the pulley, and remove the center bolt... it will slide right off. I went from underneath with the r/frt wheel off, and the lower plastic splash guard removed. Look at the belt, to determine replacement... how long has it been running with that belt?
Jack Oviatt
97 Contour
V6 , 5-speed
90,000+ miles
Posts: 21,197 |
I'm guessing the clutch on the A/C compressor is shot. The serpentine belt is squeeling on the non moving compressor pully.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,119 |
I talked with contourfreak last night and the belt could be the original. I've owned my tour for almost a year and a half, and I haven't changed the belt. Is there a way to tell if it is the origianl (i.e. ford logo or p#)
How can I tell if it is the compressor? Mine works fine! The heat blows hot and the AC blows cold! The defroster also works beautifully. What controls the compressor "clutch" is it a vaccum line or a electic control? I mentioned I've been having a rodent problem so maybe the $h!t head ate the wire/line.
Trubendz Exhaust
Custom Hood
Posts: 8,445 |
the A/C may still work, but the pulley might be lagging a little causing some extra friction on the belt.
do as stated above and pull the belt off and start the car. if the squeal goes away then it is a pulley issue or an issue with the a/c comp, alternator, or power steering pump themselves.
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 1,119 |
well I'll have to try to take the belt off tomorrow. I would imagine I should run the car without a belt for long right? Also does anyone have experience to tell me what a bad pulley might spin like? I.e. can't spin it by hand, should spin without effort, etc.
Thanks
Trubendz Exhaust
Custom Hood
Posts: 8,445 |
you only need to run the car long enough to see if the squeal goes away.
as for what a bad pulley sounds like.... llike you said, it will be very hard to turn, wont turn at all, or will make a nasy grinding/bad bearing sound when spun.
