Posts: 786 |
Originally posted by BrApple: never heard of that brand, i have the Redline Tuning kit
I have the Redline Tuning Kit on my car too.Ever since I installed it, my hood doesn't sit flush with the fenders. It makes the hood stick up a little leaving a little gap, which I hate. Anyone else have this problem?
Posts: 1,368 |
I got the struts from the GB from the company in the UK also. Mine died when I got my front-end smakced, I think it tweeked them and popped the gas. Whatever, they don't work. These struts installed using existing holes. They came with 2 ball studs and if you remove the 4 bolts (2 from fender, 2 from hood) they install with no drilling. I need some replacements as I ahve gone back to using my prop-rod :angry:. Glad I didn't drill out the rivets for the plastic thing on the hood. Here are mine shortly after I installed them: If those Focus ones fit, I am all over them!
Posts: 1,368 |
I just sent them an enquiry asking for a length, hopefully they are the same! I'll keep ya'll posted! Cross your figners for me!
Posts: 4,639 |
eric i remember u asking me about them. i just came across that website last nite so hopefully they are the same. if they can tell u the length then were in business. will be good to know where to order replacements.
bubba, yes they require no drilling at add. filed down the 2 bolt heads a bit that are on the fender below the hood hinges to give the struts a touch more clearance. they rub a very slight bit on this stock bolt head.
Hugo AIM:omegazodiac
Posts: 4,639 |
in erics pic u can see the 2 bolts. its the one closer to the firewall. mine rubbed just a little bit
Posts: 1,368 |
Originally posted by hmouta: eric i remember u asking me about them. i just came across that website last nite so hopefully they are the same. if they can tell u the length then were in business. will be good to know where to order replacements.
I thought it was you I asked, but my memory is failing m the older I get! I am screwd if it is this bad at 26! you set up the original group buy from the UK, didn't you?
Posts: 2,838 |
Thanks for the pic , Eric . I noticed you mounted yours in the rear/lower hood hinge bolts ... any reason for that ??
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
Posts: 4,270 |
it might give jsut a little more lift out of it so the hood is up further, think of how thw pivot point at a lower point increases the overall lift.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 2,838 |
Originally posted by 5V7 Dr1v3r627: it might give jsut a little more lift out of it so the hood is up further, think of how thw pivot point at a lower point increases the overall lift.
Also decreases the amount of pressure holding the hood up . I guess as long as the hood stays up if there's a breeze .
~~~~~~~ Phil
Posts: 1,368 |
No reason for the bolt placement, that is where Outlawd and I put them, not much thought went into it.
If those Focus ones work out, perhaps I should switch them to the upper bolt though.
