Posts: 9,065 |
Originally posted by Y2KSVT: Originally posted by MapOfTaziFoShoââ??¢: Originally posted by Y2KSVT: Originally posted by MapOfTaziFoShoââ??¢: From personal experience. Don't put the stock trans back in...you are totally f ing yourself and will have to pull it again.
From what Weargle has said, he's going to be driving this car daily, with very little abuse. Point A to Point B driving will not need a rebuilt/upgraded transmission, assuming his trans was still in good shape before the swap.
Mark
My shift tower bolt broke coming to a stop light when I popped the clutch and put it in neutrel.
Yeah, and that means that it will happen to every Contour drive on earth. You post some of the most general things that have happened to YOU, and act as if it's gospil. So I've snapped probably 3 roll resistor bolts, does that mean it happens to everyone? Had the engine not blown in Weargle's car, I'm sure he'd be driving with the tranny as-is right now, and he'd be fine.
Mark
How often does sh!t break on the MTX 75. If not in just my experience...ive helped pull a trans get it back in and then just have scotts bolt on his shift tower break.
Posts: 5,810 |
Originally posted by MapOfTaziFoShoââ??¢: Originally posted by Y2KSVT: Originally posted by MapOfTaziFoShoââ??¢: Originally posted by Y2KSVT: Originally posted by MapOfTaziFoShoââ??¢: From personal experience. Don't put the stock trans back in...you are totally f ing yourself and will have to pull it again.
Mark
Mark
Then rather than spend major dollars to pull a tranny or the big dollar shaft mods to the shift tower, Search up my shift tower mod and in the transmission forum. It can be done rather quickly, a morning or afternoon job and at a cost or around $5. It will save you from a broken transmission should the bolt ever break. I figured a lot of people would have appreciated the write-up and pictures and the overall simplicity of the mod itself. But of course....nope.
See My Mods
Posts: 751 |
Engine has been buttoned up; transmission has the warmonger fix, and the clutch job was finished. New control arms have been installed as have the shifter cables. CEL eliminators have been installed due to the lack of precats; I found that welding a lower attachment point from a Camaro Bilstein fit exactly in the spot on the rear manifold that was drilled out to gut that cat. Aluminum colored exhaust paint (Duplicolor 1000�ºF) that was cured in the oven seemed to do the trick quite nicely covering the weld and it looks almost factory.
Next step, dropping her in and turning the key.
Whirling dervish of FFOG.
Posts: 5,810 |
Originally posted by weargle: Engine has been buttoned up; transmission has the warmonger fix, and the clutch job was finished. New control arms have been installed as have the shifter cables. CEL eliminators have been installed due to the lack of precats; I found that welding a lower attachment point from a Camaro Bilstein fit exactly in the spot on the rear manifold that was drilled out to gut that cat. Aluminum colored exhaust paint (Duplicolor 1000�ºF) that was cured in the oven seemed to do the trick quite nicely covering the weld and it looks almost factory.
Wow. Congrats.
Tell me more about this bilstein thingy?? I'm not quite following it.
See My Mods
Posts: 751 |
A buddy had adapted a pair of Camaro Bilstein shocks to fit in his 73 Celica. He had to chopsaw off the bottoms to get them to work, and had spare metal lying around. Imagine a spool cut in half; the lip allowed the material to not fall through the hole that I had drilled, and didn't fill the hole with slag. We trimmed that puppy down a lot, and welded around the edge of it then ground that down almost flush with the rest of the manifold. If you stare at it, it looks like an anomoly from the factory.
Posts: 751 |
It's alive!
Two things: is there a pic of the front brake clips installed and I have an extra part that looks like a pin with a sheath that came from the left side suspension.
Any ideas?
Posts: 21,197 |
Should be on the outside. Have no idea on the "sheathed pin" w/o a pic.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 751 |
Posts: 21,197 |
Still have never seen anything like that. You sure it's off of a Contour?
-'96 SE MTX 3L
Posts: 751 |
It has "Ford" stamped on it & isn't from either a Miata or a Goat.
