Page 6 of 12 1 2 4 5 6 7 8 11 12
I went to the CAT cams web site and found very little information (none) other than the printed specs. They do say that they will answer questions so it would be best to actually try to find out what they have to say. If there would be a decrease in power at low rpm then you do not want taller gears. Remember that there will be an increase in power just by virtue of moving from a 2.5 to a 3.0.
Time to get some more info, thanks for your insight .
Aaron
Originally posted by Stazi:
$1500 heads vs. no trans work or headers
Not quite Using the 3L heads you save on valves, plus we do all the hard work of matching the slip port intakes AND a full pnp not half azzing it and just getting the intakes to match up. In the end its a bolt up process and around $1100-1200.
Also as FYI on every set I have sold even low milieage units with less then 10k miles on them we have found numerous guides cracked/worn out of spec, and seats improperly seated!!
I always trusted they were bullet proof and didn't wear but I'm starting to think differently.
W
weargle Offline OP
W
Thanks Kinger. That's the reason why I went with his heads. Now if the daggone Ford dealership had head bolts and gaskets, they'd be installed now.
Whirling dervish of FFOG.
Yea because they should keep a stock of parts that are rarely needed. Overhead is great.
Jesse - not knocking your work at all - my knock was at weargle who went to the trouble getting PNP heads from you and then decides to run the stock POS precats on them. IMO that's just oxymoronic.
I know chief just correcting the price, I'm trying to get it as low as I can for you guys. The 2.5L heads are still $1500 though.
Even though wes was going to start with pre-cats its no so stupid to do that then someday add the headers. Obviously smarter then trying to add pnp heads down the road.
9
This is true!
1999 Cougar V6 MTX SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
He obviously hasn't done a set of headers on a Duratec while IN the car - it's a MAJOR PITA!
The ease of doing them NOW with the engine out - 15 minutes vs 4-5 hours is worth the $350 you spend on them now.
The ease of doing them NOW with the engine out - 15 minutes vs 8-10 hours is worth the $350 you spend on them now.
Fixed
