Posts: 1,336 |
Originally posted by pole120: The nut goes on the engine side....the tab on the bolt rests into cast slots on the trans and prevents it from turning....I'll take a pic tonight if you'ld like....
No need to take a picture ... I will have it installed minutes after getting home ... the description makes perfect sense. Thanks for the offer though.
Posts: 3,037 |
Originally posted by Judge: Originally posted by todras: Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: sorry I can't pay THAT much attention!
Then don't post!
Oh...and your posts all make cents?
Dollars and cents!
Posts: 1,336 |
It's one thing after another with this car ... must keep a level head ...
Discovered why the battery was dead/dieing ... the 175am "Mega Fuse" on the fuseblock between the starter and alternator was blown. To make matters worse, I tried to remove the "post" nuts to get at the fuse and the black casing holding the block together cracked ... thanks Ford!
On a good note though, the headers fit damn well and the oil return line has plenty of clearance. Oh yeah, I will also post pictures tonight of what the oil level in the pan looks like with less than 5 full quarts in it (about 4.75-4.9 quarts). It only leaves roughly 1/4" to the top of the pan. Add in the 1/8" gasket and another quart, and I'm very glad I decided to tap the block
Posts: 7,025 |
Originally posted by fastcougar: Discovered why the battery was dead/dieing ... the 175am "Mega Fuse" on the fuseblock between the starter and alternator was blown.
i had the same problem. Replaced the alternator and the battery kept dying.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,336 |
Originally posted by beyondloadedSE: Originally posted by fastcougar: Discovered why the battery was dead/dieing ... the 175am "Mega Fuse" on the fuseblock between the starter and alternator was blown.
How much was the fuse? This looks identicle, but the 32volt (I think is just the MAX it can handle) is throwing me off: http://shop.sailnet.com/product_info.php/products_id/2545
Posts: 21,197 |
It's just a 75A megafuse. Pretty cheap.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,336 |
Just ordered the Fuse through Bill Jenkins along with the post style coolant sensor in the crossover pipe. Fuse was like $4.
Posts: 1,336 |
OK, here are the pictures of the oil pan off the engine, leveled and then filled with just less than 5 quarts of oil (roughly 4.75-4.9qts.)
How this translates to oil level on the dipstick
Now for a teaser:
Posts: 9,602 |
So when are you going to coat those headers?
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,336 |
After mockup, the entire setup is going to be broken down and sent to the fabricator for welding. During that time, I will be installing the stock setup and will breakin the car/clutch N/A. When they get back from the fabricator, they are off to JetHot
