Posts: 5,810 |
Originally posted by BurritaSVT: So you are staying stock internals? Seem like another 600 you put some better pistons in at least. Seem that the rods are good for more than 400 hp. What about the valves stem seals hope you least change those they come with the kit. Hope things work out for you just do it one time.....
I hate to break this to ya bud, but the stock pistons in the '01+ engines will also hold 400 HP. But that's only if you tune the engine right and have an intercooler.
See My Mods
Posts: 431 |
Well yes it has been proven to take that but why balance the crank to a factory piston? Pay 300 for nothing unless he was going to change something. The motor comes balanced enough for stock internals right?
99 SVT #198 blk/blue
Spec 3/quaife/stage 2 shafts
T3/T4 fully built 3.0
ported heads
water injec./intercooled
13.2 @ 107 mph
clifford alarm and turbo timer
koni struts H&R springs
intercooler for sale
Posts: 68 |
Originally posted by warmonger: Originally posted by BurritaSVT: So you are staying stock internals? Seem like another 600 you put some better pistons in at least. Seem that the rods are good for more than 400 hp. What about the valves stem seals hope you least change those they come with the kit. Hope things work out for you just do it one time.....
is that 400 WHP with a good tune and intercooler? cuz i gots those
Cougar is no more, parts for sale.
Built escape 3.0 w/ 8.5:1 pistons, PnP heads, ovalport/mazda6 cams, SVT manifolds, the works
entire car for sale PM me if you want a part!!!
Posts: 5,810 |
Originally posted by BurritaSVT: Well yes it has been proven to take that but why balance the crank to a factory piston? Pay 300 for nothing unless he was going to change something. The motor comes balanced enough for stock internals right?
Uh, and your point is???/
The factory rods and pistons can easily withstand 330-350 ft-lbs of torque. I've already done that. IF the rpm range is stock, calculate what 330 ft-lbs of torque will be at 6500 rpm?
EXACTLY!! ![](/ubbthreads/images/graemlins/cool.gif)
As far as balancing, it is perfectly ok and sometimes worth the money to get a factory setup fully balanced. Not everything comes right(correct) from the factory....as is evidenced by some motors spinng smoother than others from the day the roll off the assembly line. I wouldn't do it unless I was updating the motor and felt that it was a bit too harsh when revving.
So you are correct. Why waste the money? I wouldn't.
See My Mods
Posts: 728 |
Originally posted by pole120: Originally posted by NVMYSVT: Trev...
Good luck on your projects.. remember if you need any Fel-Pro or Sealed Power parts to get them from my work using that 5% discount code listed in the Duratec Maintenance section..
Plus I normally place all the Federal Mogul orders so I'd take care of you good
Where do you work?
www.rockauto.com
Crispy
99 Cougar - Arancio Atlas/Grey Graphite Pearl Custom Widebody
98 CSVT - Silver Frost #4014/6535 - Born 10/21/97
98 CSVT - Silver Frost #4085/6535 - Born 11/10/97
See My Rides
Posts: 1,089 |
Yeah thats a sweet garage. I would love to work on another 3L. I gotta call people about swaps they have been talking about me working on. The only bad thing I saw is that you ahve a ghey towel on your car!!
Posts: 9,065 |
Are you in MI?! You can come by and work on mine. I have a propane heater and my garage isn't too bad either. ![](http://memimage.cardomain.net/member_images/10/web/310000-310999/310464_264_full.jpg) Once I get back from CO on the 23rd...I will do the X MAS thing and jump back into the 3L on the 26th.
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Posts: 9,065 |
Posts: 5,810 |
![](/ubbthreads/images/graemlins/laugh.gif) Actually it hasn't been hijacked, the poster is the one that changed it over to garage pictures and discussions of his work in his garage. So I'd say his thread is....under new leadership direction.
See My Mods
