Posts: 9,065 |
Originally posted by todras: What car is that? I'm guessing it's the grey SVT from fordcontour.org? How could you not know that car would be hacked? We saw the pics of it.
It looked fine to me.
Posts: 10,015 |
Terry's $0.02:
fastcougar's T/C engine...
before we all jump he should do a correct
compression test then change the 'O' rings around the
plugs and cam gasgets...that oil on the plugs is
clean/fresh and not from the cylinder...FWIW!!
He has a point.
My only reservation to it being that simple is that form the pics of the threads it looks like a mixture of oil and aluminum filings. ![](/ubbthreads/images/graemlins/help.gif)
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,336 |
Well, the reason for the purchase was simple ... buy the car, strip the turbo system down and then refabricate it on the Cougar and possibly duplicate the fabricated work as a "kit" for others. And YES, it's "That Car" ![](/ubbthreads/images/graemlins/troutslap.gif) Warmonger: I know, my company has an employee who is the company lawyer who came he from a 20+ year private practice. He also suggested I find another way, thru personal negotiation with the previous owner, and I have. We agreed upon him giving me some money back to fix the other issues and to have the car tuned ... that was BEFORE last night's find. Giving it a lot of thought today on the ride to work (1 hour drive one-way), I will have to eat the loss and drop in a 3L ... have fun explaining that one to the wife ![](/ubbthreads/images/graemlins/shocked.gif) Since I'm not at home now, I don't have access to the pictures, but the wastegate setup is as suspected: small oriface (have yet to measure) for the "built in" wastegate that doesn't exist. So, an external wastegate was used to replace a non-existant internal one.
Posts: 6,106 |
I could buy that. Remember the little issue we found with oil on my plug Stazi? Might it be the same scenerio?
Mark
2000 Black CSVT
Posts: 10,015 |
Did the small tube for the wastegate extend past the flange and fit tightly into the internal wastegate hole in the turbine housing or is it flush with the flange, just like the downpipe (therefore making the wastegate useless!)?
AUSSIE ENDLINKS $70
Posts: 1,336 |
He has a point.
TH is correct and I am returning the Summit compression tester and getting a quality leak down test kit with multiple threaded attachments since the spark plug holes in these heads are fairly well recessed. Nothing is happening until I can do a proper test.
BTW, that is Anti-Sieze, not aluminium
Posts: 5,810 |
before we all jump he should do a correct compression test then change the 'O' rings around the plugs and cam gasgets...that oil on the plugs is clean/fresh and not from the cylinder...FWIW!!
He has a point.
Possible. It could be that the oil ran down into the spark plug hole from the valve cover o-ring not sealing around the plug hole, but on the other hand if it ran for any length of time like that then the fresh oil will have baked onto the plug body. And there is a lot of oil cooked onto the plug electrode. Its definitely burning a significant amount of oil. The aluminum filing look could just be anti sieze compound mixed in from the plug threads. So he probably has multiple problems.
See My Mods
Posts: 7,117 |
WOW! That is a terrible install... FWIW, I think your plug problem is just the O-ring leaking around the valve cover for #5. I notice that was suggested by Terry & is a good call. One of the plugs on the Zetec I have looked exactly like that after the timing belt change. Fresh seals for the valve cover fixed it, no problem. Plug looks clean like the others now that there is no misfire issue.
Posts: 21,197 |
There were pics of it and the error was pointed out in that post.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,197 |
Wouldn't you be able to see down the plug hole to see if thier is a leak or some residue? Hopefully it is just a gasket. Did he have them painted/PC'd. Maybe just reused the old gaskets. Maybe they are just worn.
-'96 SE MTX 3L
