Posts: 1,336 |
Originally posted by todras: Wouldn't you be able to see down the plug hole to see if thier is a leak or some residue? Hopefully it is just a gasket. Did he have them painted/PC'd. Maybe just reused the old gaskets. Maybe they are just worn.
Yes, and the top of the piston appeared the same as those in cylinder #4 & #6, but no residue. I have a set of valve cover gaskets, so that's not an issue I can't solve in 20 minutes. Pending the leakdown test results, I will begin to fully tear down the UIM/LIM, replace the injectors with the stock 19#'s, replace the plugs with double plats and see how she runs.
Posts: 10,015 |
I see he drilled a hole through the body to route the outlet of the turbo out of the engine bay to the front for the intercooler, right?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,336 |
Originally posted by Stazi: I see he drilled a hole through the body to route the outlet of the turbo out of the engine bay to the front for the intercooler, right?
No, but there is a hole to route the intake from the intercooler outlet ... at the corner of the "box" next to the washer bottle
Posts: 10,015 |
You kinda lost me there - I guess I need to look at my engine to understand. From your pics though it seem like the outlet from the compressor goes down and through the side of the inner frame rail to that cavity under the fuse box, and - from my guesses - to the intercooler inlet.
More pics man - more pics!
Or is THAT the pipe from the compressor outlet going towards the front of the car, in thr ight of the above picture??
AUSSIE ENDLINKS $70
Posts: 1,336 |
No, it "squeezes" through, just by the hair on it's chinny chin chin between the frame rail, A/C condenser canister & frame rail "turret".
Posts: 10,015 |
If you can take a few pics of the IC piping from the front - with the bumper off - that'd be sweet!
AUSSIE ENDLINKS $70
Posts: 829 |
I am assuming that this is not an ADC built and installed kit, huh?
SVT Parts For Sale!PM Me.
2006 M6 Cyclone Gray GTO
1995 Mazda Protege Commuter Special
93 FXDWG Dyna Wide Glide
I'm A TROLL Now!~
Posts: 1,860 |
Welcome to last week.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 2,097 |
Originally posted by Keyser: Welcome to last week.
last week?? How about 2 months ago??
98 E0 SVT with some stuff
Posts: 1,336 |
Considering it got "stuck and sheared off", how would I go about removing that bolt from the turbine housing without making matters worse WITHOUT a drill press? Guess I need to get a drill press, drill out the old "shank" to the same depth as the other holes and then "pick" at the remaining threads. Doing this by hand will no doubt destroy the treads if the drill bit doesn't stay put exactly where you need it.
