Posts: 536 |
could a third gear grind be caused by poorly adjusted clutch or shift linkage. Just wondering.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 21,197 |
Highly doubtful. You have a 6 year old car. I'm guessing over 80k miles. Time for new synchro.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 536 |
third gear grind could indeed be caused by a misadjusted shiftlinkage, but not by the clutch. if the clutch wasnt disengaging all the way it would cause a hard shift in all gears. on our trans 1, 2, 3 all have double synchros, so it probably is you synchro. i have a hard shift into second sometimes. but mine has 208000 miles on it so mine is almost definatly the synchros. try adjusting your cables first and if that doesnt change anything then you know its internal. it could also be the a bent shift fork. does it ever pop out of third?
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 21,197 |
Originally posted by striker2: third gear grind could indeed be caused by a misadjusted shiftlinkage, but not by the clutch. if the clutch wasnt disengaging all the way it would cause a hard shift in all gears. on our trans 1, 2, 3 all have double synchros, so it probably is you synchro. i have a hard shift into second sometimes. but mine has 208000 miles on it so mine is almost definatly the synchros. try adjusting your cables first and if that doesnt change anything then you know its internal. it could also be the a bent shift fork. does it ever pop out of third?
And it would have hard engagement in all gears, as you went on to state, if the cables were out of alignment. Haven't heard of anyone bending a shift fork in an MTX-75.
-'96 SE MTX 3L
Posts: 536 |
almost 80k, but the tranny has less than 20k. It was rebuilt with the "revised" one snap ring syncro, from what I can gather. Just hoping. Thanks sirs.
Posts: 21,197 |
Uh oh! That's why. Single style instead of the twin. Go to any Focus forum and ask them how great the revised single is. Who told you to put that in? A dealer? Take it back!!!!!!!
-'96 SE MTX 3L
Posts: 536 |
thats the only part my former half assed tranny shop could find, anywere.
Posts: 21,197 |
Because Terry bought them all up.
-'96 SE MTX 3L
Posts: 536 |
Originally posted by todras: Originally posted by striker2: third gear grind could indeed be caused by a misadjusted shiftlinkage, but not by the clutch. if the clutch wasnt disengaging all the way it would cause a hard shift in all gears. on our trans 1, 2, 3 all have double synchros, so it probably is you synchro. i have a hard shift into second sometimes. but mine has 208000 miles on it so mine is almost definatly the synchros. try adjusting your cables first and if that doesnt change anything then you know its internal. it could also be the a bent shift fork. does it ever pop out of third?
i havent either but nothings impossible. shift forks do bend or break. bot common
97 contour gl mtx
19mm bat sway bar
