Posts: 31 |
A couple of questions that seem tough to get answers searching on. I am doing a full 3.0 swap into my CSVT. What do I do with the IMRC? Can I just leave it off and not mess with connecting the wiring? I am currently planning to just reuse the SVT OBC.
Are chips worth it, or just connect it all back up to the SVT OBC? I am not looking to race, just get back on the street. My total layout for the engine and gaskets will be around $600 plus a new clutch and pressure plate, and a $400 chip seems like a lot of money. Are they worth it?
ATX bushing, cut it off or extract it?
Fuel rail mods, what do you use for the pipe material? I plan to splice my SVT parts onto the Taurus, what is the raw material used? Does anybody do this mod, and if so, how much?
I think I have pretty much everything else coming together, I appreciate your answers to these items.
1999 Green Contour SVT 3.0
1999 Black Corvette 6 Speed (FOR SALE)
2000 GTP Pace Car
1993 Lumina Z-34 (SOLD!!!!)
2000 Blazer ZR/2 (FOR SALE)
1993 Eagle Talon (my baby)
1970 Camaro, since 1974
Yeah, I need more cars!
Posts: 10,015 |
If you do a full 3L you throw the IMRC in the trash. Get a 2.5L to 3L chip from ADC and have them turn off the IMRC functions all together and adjust the fuel and timing accordingly.
As for the fuel rail mods, I can do them - PM me for the price and details.
The ATX bushing you can cut-off with a die-grinder and cut-off wheel.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 31 |
OK, getting closer to the end of the swap, planning to drop the 3.0 in this weekend. I am plannig to run my SVT chip at the beginning. My question is, if I hang the IMRC box off to the side and hook up the wires to it, maybe even cut off the cable, will the CPU think all is well and run properly? I may chip it later, but just want to get it running.
2000 GTP Pace Car
Posts: 4,051 |
Relating to this post, I have a similar question.
Having a 3L hybrid, should I also shut off the IMRC, or is it not recommended for my setup?
Posts: 1,087 |
This might help you guys. It's straight off of DemonSVT's own website.
Matt
2002 Subaru Impreza WRX (WRB Stage 4+)
Old Rides:
1999 Sil-Fro SVT Contour 3.0L with goodies (Totalled 6/21/06)
1988 Bronco II (Sold)
You know you launch hard when you beat oncoming traffic through their own crosswalk lines.
Posts: 611 |
You cannot cut the cable off the IMRC it senses tension on the line and if it doesn't have any tension on it normally and when it pulls it will pop a CEL. I normally hook them up to a spring mounted near the driver's side strut tower when a chip isn't sourced right away.
As far as having a hybrid keep the IMRC for now unless you want to gut your lower intake manifold and weld the holes up.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 10,015 |
You can shut off the IMRC in the chip and then disconnect the box all together.
AUSSIE ENDLINKS $70
Posts: 4,051 |
Originally posted by Stazi: Originally posted by CSVT1214: Relating to this post, I have a similar question.
I know that's how it would be done, but would I benefit at all, or no?
Posts: 10,015 |
If you are using the full oval port UIM/LIM then you can't use the IMRC anyway.
AUSSIE ENDLINKS $70
Posts: 4,051 |
Originally posted by Stazi: If you are using the full oval port UIM/LIM then you can't use the IMRC anyway.
Well that ain't me, so that answers my question.
