Posts: 1,130 |
I got this PM from SVTcuervo and thought I should share it with you guys. I am in the process of ordering a Ford oem TOB, because I just dont want to take a chance on this spec TOB. Steve at tousley got one in today and it measures at only 68mm. Does anyone know what the 4cyl TOB is supposed to measure? The v6 is 78mm right? Quote:
Well Randy...I have some news...
I've just gotten off the phone with the big guy at SPEC and there seems to be some communication problems with the insubordinates. For years I've been told that these peices are Ford OEM in a Ford boxes and today I'm told that this is untrue. The TOB is a "stock style" peice manufactured by INA. This is absolutely opposite anything I've ever been told by any of the various SPEC representatives, however it seems to hold true in current cases....
There has been discussion that this "stock style" peice is unreliable, however, I've never personally dealt with such a complaint. I recognize you concern and will be happy to assist you with anything you need...
Let me know...
Thanks RamMotorsports
Originally posted by Who the F are You?: does your family tree not have any branches on it?
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 1,130 |
when ordering a ford OEM TOB: Steve at Tousley ford says that ford has the catalog backwards for the Throw out bearings. You can measure them to make sure, but another way to check is the engineering code on the part. v6 TOB's end in BA and 2.0L TOB's end in AA.
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 4,141 |
Originally posted by todras:
1) Place your replacement TOB on a flat level surface and measure the height of the TOB. V6 vehicle TOB's should measure around 78mm high. I4 vehicle TOB should measure around 69mm high.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 6,910 |
did you look over this thread to see if it answers your question or did the question come about because of this thread?
- 95 Mystique LS - Zetec/5spd
Posts: 21,197 |
Originally posted by RandyCSVT: I got this PM from SVTcuervo and thought I should share it with you guys. I am in the process of ordering a Ford oem TOB
And then Ford sent you a Zetec TOB. Well I'd go with the Spec. Looks identical to the Ford part to me. Look at everything I posted under Brapple's post. Warmonger and Demon have been using them with no ill reports. They are putting down the most power and have ran them for quite some time. Not worth the $80 to me. The Spec units will hold up just as well.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,141 |
Originally posted by todras: Well I'd go with the Spec. Not worth the $80 to me. The Spec units will hold up just as well.
Originally posted by todras: For the extra $25 I'd get a new Ford one so I won't have to worry about pulling my trans again!
would you either quit being sarcastic or pick a damn side.....
please
Totaled 02/12/06
Posts: 1,130 |
Originally posted by BrApple: did you look over this thread to see if it answers your question or did the question come about because of this thread?
This question came up because of this thread. I have been researching this topic for a while. It seems like the spec one is safe, but I would rather not take my chances.
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 1,130 |
Originally posted by todras: And then Ford sent you a Zetec TOB.
Ford never sent it to me. I had steve check the part before shipping it. He checked the part, called me, figured out the catalog problem, and will be shipping me the correct part soon.
Double troutslap for you!!!!
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 9,602 |
Originally posted by pole120: Originally posted by todras: Well I'd go with the Spec. Not worth the $80 to me. The Spec units will hold up just as well.
please
It's toadass. He has no side or clue. Get used to it.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 21,197 |
Originally posted by DemonSVT: Originally posted by pole120: Originally posted by todras: Well I'd go with the Spec. Not worth the $80 to me. The Spec units will hold up just as well.
please
Yea umm pole pulled that from a post before I found out it's the same unit and posted the results AND pictures. So FU. I don't have a side. When did we start picking sides? I'm guessing this is how YOU go about gathering information. You go against whatever Terry says no matter the outcome or how foolish you look. My TOB info is based on real life inspection. Not listening to what someone else said months and years ago. You're the on that stated it's a Ford unit. Now their is hard evidence that it is a reman as terry stated contrary to what everyone else said. It sounds like no one knows for sure but Spec themselves. The units look identical to me to make up your own minds.
-'96 SE MTX 3L
