just noticed one of mine are loose and starting to sag... i dont want a peice of ice or something to form on it and knock it off. Is there any way to keep that bad boy from moving? I dont remove them anyway to jack up my car.
Mike
98.5 Black CSVT
#5291 of 6535
(Oo.<xx>.oO)
o xxxxxxxxx o
use some kind of zip tie inside them, in case they do fall off, it'll catch them. also play with them to make sure they are sitting correctly...all 4 notches in the right place.
Originally posted by hot3dog3lucky3: use some kind of zip tie inside them, in case they do fall off, it'll catch them. also play with them to make sure they are sitting correctly...all 4 notches in the right place.
yup this is what I did. Works well
SOLD Polarg M-28 super bright white bulbs. Replace yellow stock license plate bulbs. See add in classifieds.
WANTED:: EVO style CF hood
I did the same. Just leave it loose enough so that you can get them off just in case. I used two zip ties on each piece. One on the skirt and one on the insert and looped them together.
Former - 98 CSVT E0 T-Red 4/4/97 #173 of 6535
Dear Santa
i dont trust that plastic catch piece, so i put a little metal tab under the actual side skirt that swings under the removable piece, you cannot see it at all unless you are under the car, works great and no worries
