from the tranny to body of the car,near the stock filter postion
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
There is a small bracket for wires to plug into on the tranny. A ground is suppose to go under that small bracket to the fenderwell just under the intake. You should be able to tell because the eyelets will be sized differently. One for the larger bolt that holds it to the transmission and one for the smaller bolt that holds it to the fender.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
There is also a thin ground strap that goes from the top of the trans, away from the trans-toengine mounting bolts, to the drivers side frame rail, near the fues box.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
