Posts: 1,119 |
On a side note I've been following this thread. Here are plausible solutions to the problems:
1) rusting in general: -Painting the rails after installation with rust resistant paint -Undercoat the body around the rails and the rails themselves after installation -Do both
2) Caps or no Caps -If capped, small holes should be drilled at mentioned above because they most likely will not be "air" tight. -If uber worried about rusing with caps drill holes and install small upward facing pipe to avoid water intoduction while allowing the hole for moistrue evapuration. -If uncapped, probably should drill holes alot bottom for drainage as water/dirt/road salt will get into the rails - Also regular maintance and ensuring dirt/road salt is not sitting inside the rails will prevent the worse corrsion.
thats my 0.02.
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 5,621 |
Chris: if and when we get them - I am using the same welder, I mean the one u r gonna use
Posts: 2,978 |
Originally posted by R_G: Chris: if and when we get them - I am using the same welder, I mean the one u r gonna use
x2
I am interested, but it really depends on my money situation when the time comes!
Learned patience the hard way
Posts: 2,454 |
Hey guys, there is a possibility I'll run into Todd from TCE at the PRI show in Orlando this weekend. If I do, I'll ask him if he's got any interest in fabbing these up.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 595 |
What about capping them and filling them full of grease?
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 4,141 |
i say cap them with a drain hole at either end and call it a day.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 7,117 |
Originally posted by pole120: i say cap them with a drain hole at either end and call it a day.
I say don't cap them 'cause they might make cool howling noises at highway speeds....
Posts: 533 |
put my name on the list, i am interested
-Ary
koni kit - hpp rstb
camber/plates - cf (yikes!)
polyroll resistors - TCA's
WR headers/ypipe -TB hiflow cat
SFC's - XCal2
-dreaming of 3L-
Posts: 238 |
Mike C
T-Red 99 csvt #490 No longer a dailer driver
Posts: 3,788 |
Originally posted by Slack Master Doug: Originally posted by R_G: Chris: if and when we get them - I am using the same welder, I mean the one u r gonna use
x2
OK. I don't have one yet but when I do I'll let you know.
