J3SVT Offline OP
just like the title says. if i were to just junk my 2.2 1993 Ford Tempo GL, would any of the parts be duratec compatible? zetez compatible? to take out and use for spare parts? thanks.
98' Black SVT Build #1915 of 6535
fuses
floormats
bulbs
Originally posted by MapOfTaziFoSho:
Can u ask him to measure his shaft and compare it to your shaft?
F
F
It must have one too many winters on it . It would be a good winter car.
J3SVT Offline OP
yup. one too many. that's what it has been used for. think it needs a new tranny.
F
F
What's it (not) doing? Maybe there is a range sensor switch (I know there was on a 1993 Sable, caused loss of reverse, and bad fluid caused it to thump in and out of lockup o/d).
J3SVT Offline OP
u mean the mlps switch...it doesn't have one. if not, i'm open to suggestions. only prob is that is not the only thing it would need. radiator fan motor and 4 new tires soon.
F
F
This site may help you,trans section Tempo site It's a different trans than the Tours by the looks. Edit: I went to their forums, they talk about the throttle valve adjustment in response to your post (it's like the kickdown cable on my Dodge, If it's wrong, it will hang in low gear) Try that adjustment, I wish I knew the procedure for your car.
What a blatantly stupid question.
Why not ask what 1974 F100 parts fit on it as well??? It has just as much in common. It was made by Ford. Well actually the Contour was designed by Ford Europe so the Tempo has more in common with the 74 F100.
BTW - the rims would fit. There's your link.
Yup i ran the stock e0's on my old tempo for a long time. Offset was way different. I had to run spacers, just so the fronts wouldnt rub lock to lock. + it looked alittle funny cause it raised the car like 2 inches, and its kinda ricey cause it says svt on the caps.
98 csvt t-red.. sho-shop intake, b&m, fidanza, spec1 clutch, Torsen, DMD,optimized Y& TB, Brullen, rear strut bar,h&r's,17" konig traffik's. "I say what I mean and I do what i say"
O
OB1 Offline
O
If you lived A little further south I'd give you the Wrecked one I have for A little bit of nothing! It was hit in the back but its 5 speed!
I don't "mod" I just fix what breaks! 98 CSVT #2527 T-Red (Limping) 98 CSVT #2228 T-Red (Donor) 98 SE Sport ATX V6 (Running again) If swimming is good for your figure, explain whales to me!
