Posts: 451 |
so all 4 of my tires are wearing at the same rate. they are good year aquatread 3's never rotated them and my alighnment is perfect. i know my spirited driving has some to do with it but i wouldnt think that much. does anyone else have these tires or had problems like this.
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 4,292 |
how many miles?..also whats the tread wear for the tires? and rotating is more important to a tires life then you obv thought
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 451 |
maybe 15 or 20 thousand on the tires and they are 80 thousand warranty tires
2000 contour V6 ATX
Posts: 1,089 |
so wait, there is something wrong with the tires wearing at the same rate? i understand they usually dont, but with your alignment perfect and all, whats the problem?
99 V6SE Sport ATX
Posts: 4,693 |
I suspect he thinks they wore out too soon. Maybe they are cruummy tires or maybe he forgot to allow for the "fun" factor.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,089 |
i see... that would make sense.
99 V6SE Sport ATX
Posts: 451 |
even with "hard driving" shouldn't the front tire wear faster than the rear?
2000 contour V6 ATX
Posts: 1,016 |
Originally posted by lizard: even with "hard driving" shouldn't the front tire wear faster than the rear?
I should learn to read.
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 4,140 |
First of all, what exactly is a "perfect alignment"? Also, how much wear are you seeing, and how did you measure it?
Posts: 1,177 |
I always assumed that the traction tires wear first, fronts in our case (I may be wrong as I never needed to checkup on this).
If everything's wearing the same, and driving seems fine, and the tire's are wearing evenly I personally wouldn't worry too much. Means you just don't need tire rotation.
Maybe check and see if you can figure whether you think the fronts are wearing less than they should, or the rears are wearing more. That will give you an idea of which end of the car is different at least.
1998.5 T-Red on Midnight Blue SVT
Build Number 5320 of 6535
