Page 1 of 3 1 2 3
#1442853 11/23/05 01:07 PM
RawBurt Offline OP
Well I have been noticing that the SVT has been making some wieerd noises lately. Especially yesterday, before I left work I gave a general look over to the front end suspension where the noises seemed to be coming from. On my 45 minute commute home at 70-80 MPH, things started getting worse. Well this is why...
Two of the studs sheared off. There was one lug nut holding the wheel on. Which a later found out was held on by barely even one thread. I'd say I was pretty luck on this one. Although, it did do a number to my rim which I'm pretty upset about.
#1442854 11/23/05 01:11 PM
That sucks! Good thing you found it before it cause any more damage!!!
#1442855 11/23/05 01:12 PM
You're one lucky dude , Robert ! That could've turned out really bad . Sorry about the wheels though . Maybe time for a new one , if it got chewed up bad enough .
~~~~~~~ Phil Black & Tan 2000 SVT Contour #2137 of 2150 35,000 miles & counting !
#1442856 11/23/05 01:18 PM
RawBurt Offline OP
I had a very long drive home with the tow truck driver (7 mph to ensure the wheel didnt fall off and plop onto the subframe), he made it pretty clear that I was lucky to be sitting in a tow truck and not an ambulance!
#1442857 11/23/05 01:49 PM
Yep, very lucky.
Glad that you are safe.
#1442858 11/23/05 02:02 PM
my ranger had that happen.. only i wasn't so lucky and my wheel went across a ditch and hit a house. the owner sued my insurance co. for over $10,000 dollars. My truck had minimal damage. Needed new stems, fender, and kingpin bolt. This most likely happened due to improper torqing of your lugs. Aluminum wheels will loosen lug nuts if not tightened down to the max.
1998.5 Diamond White Pearl SVT (#4725) custom exhaust/intake k&N/mod'ed y-pipe slotted rotors/greenstuff pads/SS lines cougar trans/FSVT shift tower/Torsen 16lb. flywheel 18" Velox VX-8's with some rubba bands
#1442859 11/23/05 02:09 PM
I had that happen once. I was pissed. The tire shop that had just mounted my wheels a week earlier overtightened my lugs. Fortunately it didn't hurt my wheels or anything. It was scary though!
#1442860 11/23/05 02:13 PM
wow, that could have been really, REALLY bad!
99 V6SE Sport ATX
#1442861 11/23/05 02:28 PM
RawBurt Offline OP
Do I need to remove my hub and have new studs pressed in?
#1442862 11/23/05 02:57 PM
At least you had better off than Bmonje. His little occasion had his wheel come off, roll next to him all while he was sliding on one wheel and one rotor and then watch his wheel roll across 4 lanes after he came to a stop.
Obsticle course, anyone?
Glad to see you did not enjoy the same fate. How about the rim itself, any pics of that? I imagine it's too big a kick in the nuts to want to show that, I do sympathize!
Page 1 of 3 1 2 3
