Posts: 3,165 |
Originally posted by SQPlus: I just want to verify which of you still need the pre98 parts I have been looking for.
[b]ESCI have a headlight switch, haven't got the console but I know where one is. JPettDo you still need a guage cluster? I thought I saw that you found one. 97 MTX Zetec ABS right? sqplus@my99svt.net[/b] Ya, I still am looking for a cluster w/ a tach for a 97 zetec w/ abs.  If you happen to come across one, please let me know  thanxs. BTW, it's an atx.
Posts: 2,657 |
TTT
Still looking everyone...hopefully I can go pick up some stuff tommorrow.
Posts: 3,950 |
Posts: 2,657 |
Posts: 3,165 |
Originally posted by SQPlus: TTT
Still looking everyone...hopefully I can go pick up some stuff tommorrow.  Thanks again for helping
Posts: 175 |
JPett: I like the custom Ford badge you have on your trunk lid. Where can I get one like that?
SQPlus: Thanks a ton for keeping an eye out.
Midnight Red '95 Contour SE ATX Just completed the lighted moonroof switch mod. Its great! www.webcentrix.org/contour_se.html "The whole purpose of a car is not to go fast it's to get from point A to B, and if you can afford it, to get from point A to B with some sense of style." As seen on the Ricecop.com boards
Posts: 3,165 |
Originally posted by VaTech_95SE: JPett: I like the custom Ford badge you have on your trunk lid. Where can I get one like that?
I made it that way. You can do the same. just remove the emblem (just the clear part) and sand off the back and remove the chrome in the lettering. then i just used some blue acrylic paint and painted over the letters, sanded it off again so the oval was clear and then used some metallic rustoleum to spray over it and then several coats of sealer. then just glued it back on after it dried really well.
Posts: 2,657 |
No sweat guys, just hope I can get all the requested parts.
Posts: 82 |
Thanks
'98.5 Contour SE - Zetec Powered '00 Focus SE rims with Toyo FZ4's Rickbrook Shifter Knob Bullit Gas Door Accel Coil with Ford Racing Wires KVR Cross Drilled Rotors with KVR Carbon Fibre Pads
Posts: 175 |
SQPlus: I didn't see that eBay auction linked off of here till today, and the driver's side mirror was relisted so you don't have to sweat finding it for me. However, if you can find an MTX shift boot...  I guess they all come in black, and that's just fine. Thanks a ton.
