Posts: 330 |
Yeah. I just set it on a little stand i made where the spare tire is... i ran four guage from the front one to the rear battery, and then i just grounded it to the frame. I bought 60 ft of edead... 3 layers on trunk lid, and then 2 on the back (towards rear bumper) part of the trunk.. The box is 9 cubic feet so it takes up the whoel trunk. The Edead is worth it though. It rattled so bad but now its a lot better.
97 V6 ATX 20,000 Miles
alpine cda 9811
Alpine MRV-F357
hifonics brutus BX2000D
2 Kicker L7 15
I NEED GREY LEATHER DOOR PANELS!!!!!!
Flip out monitor
PS2
Spr-175a
SPR-69LP
SPR-57LS
60 Ft EDEAD
I feel Guilty, Oh so guilty
Posts: 4,789 |
Originally posted by KnuKonceptz: Originally posted by SteedaSVTââ??¢: Your not going to be drawing 170ish amps unless your playing extreme volumes...
Upgrade the big 3 and get another battery and you should be all set
Or playing test tones for SPL. Music will never reach levels like that. For extended playing time you may get some peaks, but the real draw is when doing a sweep or a constant low cycle (60 or lower) This varies by the subwoofer's Impedance curve.
As for adding a second battery, no need to connect it to the alternator. Just connect the front battery to the rear battery and then the amps to the rear battery. Just the postive wre needs to be run, ground each battery with the same gauge wire used to connect them.
To expand on this a little, music (even extremely compressed bass heavy material) will have a crest factor on the order of 6dB and typical pop music will be above 10dB. Crest factor is the difference between the peak and average output in a song. Sine waves have a crest factor of 3dB. Seriously clipped sine waves (nearly square waves) have a crest factor approaching 0 dB. To translate these numbers to this discussion we have consider the amp efficiency, power, and voltage.
If crest factor was 0 and you were producing the full 1000w and your amp was 100% efficient, you would get the following:
1000w/13.8v = 72A
Obviously, it's not 100% efficient, and being from 98 with crossfires claim of older technology, I will assume it's a class a/b amp and lets say it has 50% efficiency(typical). meaning that 50% of the energy is disappated as heat.
You substitute 1000w with 2000w because it is wasting 50% on heat and now you have 144A of current draw.
But, you throw a CD with music in the deck with 10dB crest factor and you have your amps properly dialed in, and now your average current draw drops to a paltry 14.4A with an occassional 144A draw. Not exactly the most strenous load on the system. Under harsh, but not untypical conditions (amp clipping, heavily compressed music) your average draw would be on the order of 60-70A. Crank the gains fully and play sine waves and your alternator will hate you.
Avoid batcaps is the general advice I have read.
-Mitch Hedberg
Posts: 330 |
WOW...So would it help to buy one of the "yellow tops" from wal mart, the 1000 cold crankin amp ones
alpine cda 9811
Alpine MRV-F357
2 Kicker L7 15
Flip out monitor
PS2
Spr-175a
SPR-69LP
SPR-57LS
60 Ft EDEAD
