Posts: 733 |
Thanks, guys.
I'll locate it tomorrow, and order the piece. Thursday I'll be off from school, so I'll dedicate it to working on that.
Should I check it for anything else, however?
Is my car for sale? PM me if you're in South FL.
Originally posted by XKontour98: Haha that's awesome! Go GM!
YES, SIR!!!
General Aviation is Looking good right now...http://www.beapilot.com
Posts: 7,117 |
If you don't have the throttle hang fix installed yet, you might consider that. I can give you mine so you can test it in your car for a few days. BUT I'LL WANT IT BACK !!
Posts: 1,246 |
Originally posted by TourDeForce: I replace my TSS without removing the driver side wheel. Just turned it full left, reached in & did the deed. Took all of 10 minutes - including getting out the tools...
I'm nearby ('bout 500' north of the border), give me a shout if you need a hand.
That thing gave me hell. Took almost 12 hours to replace because it broke. Thanks to btrautman (sp?) for his fix did it finally come out.
Posts: 733 |
Originally posted by TourDeForce: If you don't have the throttle hang fix installed yet, you might consider that. I can give you mine so you can test it in your car for a few days. BUT I'LL WANT IT BACK !!
I haven't tried the throttle hang fix yet. But I will also add it to my to-do list.
Should I do the throttle hang fix before the TSS?
YES, SIR!!!
Posts: 733 |
NEVER MIND I looked into the wheel well a few minutes ago and discovered that the TSS was disconnected. I found the connector just hanging there. I connected it, and did a little road test. The hard shifting is gone, and it will go into overdrive!!!! Thanks for the help guys! I really appreciate it.
YES, SIR!!!
Posts: 1,456 |
Congratulations!!  Stuff works better when it's connected! Happy Thanksgiving. Apparently, that problem won't light the Check Engine light.
Posts: 47 |
Sort of sad that when you disconnect a critical sensor, the CEL/MIL won't go on. Yet other times, you get pesky codes when the vehicle is running just fine. Ford misses the quality boat again. Just and FYI; the EPA compiled a report of the most common DTC's reported....
Any guesses as to the most popular DTC's???
Here are the top 10... Rank____DTC____________________________________________% 1_______P0420 --Low Catalyst Efficiency______________10.7% 2_______P0171 --System Too Lean______________________10.1% 3_______P0401 --EGR Flow Insufficient_________________7.0% 4_______P0174 --System Too Rich_______________________6.0% 5_______P0300 --Random Misfire________________________4.6% 6_______P0141 --02 Sensor Heater Circuit______________4.5% ________________Malfunction 7_______P1443 --Ford Evaporative Control______________4.2% ________________Valve Failure 8_______P0135 --02 Sensor Heater Circuit______________4.0% ________________Malfunction 9_______P0133 --02 Sensor Circuit Slow Response_______3.9% 10______P0455 --Evaporative Emission__________________3.4% ________________Control System Leak Detected ________________(gross leak) _______________________________________Total Top 10__58.5%
Not a single transmission code in the bunch!
