Page 2 of 2 1 2
#1441575 11/22/05 04:09 PM
IF you decided to go with tapping the rear speaker wires, I can try to help you out since that had been done to my SVT before i got it. (since then i reconnected the rear speakers and fixed things up a bit) the rear speaker wires were tapped in the B-pillar. It comes off with a few screws and a bit of fighting. i dont remember the exact color of the wires, but they are bundled up with the rest of them. check the ones coming out of your HU/Wire-Harness/Factory Amp (depending on your setup) for the colors. you can tap them here and run them down under the rear door sills to the trunk. (you have to tap them here because they go into the door after that point).
i dont know if that helps.
#1441576 11/22/05 06:23 PM
DUDE! Thank you very much!!!
Thats what I have been trying to get an answer to!! Am I right on the rca/jacks low input deal?? I have always just tapped into the rear speaker wires for my right and left signals and have never had a problem!
Is it a 'cleaner' sound or signal going form the rca's in the HU???
#1441577 11/23/05 03:51 PM
Originally posted by jdfet:
Is it a 'cleaner' sound or signal going from the rca's in the HU???
yes
What do you mean, rhetorical question? 1998.5 SVT --> http://www.cardomain.com/ride/2155561/1 #4619 of 6535, born Feb 18, 1998. i'm a smarta$$, don't take it personally
#1441578 11/24/05 11:28 PM
im just taking a guess, but low level could be because the signal is not amplified, and its just 4 volts( depends on deck) and high level because the signal (takin from head unit output) is amplified. The rca's have way better sound quality....
97 V6 ATX 20,000 Miles alpine cda 9811 Alpine MRV-F357 hifonics brutus BX2000D 2 Kicker L7 15 I NEED GREY LEATHER DOOR PANELS!!!!!! Flip out monitor PS2 Spr-175a SPR-69LP SPR-57LS 60 Ft EDEAD
#1441579 11/25/05 09:17 PM
H
H
sounds like your amp has both low level and high level inputs...rca and speakerlevel inputs. the rcas will be better
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
