Posts: 101 |
I got a call from my wife on Friday saying "Honey, don't worry I'm okay, but I crashed the car".
She rear-ended a Ford box truck and the rear steel bumper went through the oval grill, through the radiator, bent the radiator support, but did not hit the engine.
So how easily can the radiator and the support be replaced? I know the rad is simple enough, but the support is what I'm worried about. I was going to go to a u-pull-it junk yard and get the parts, but should I bother? Or am I wasting my time. The hood and fenders and bumper are actually not damaged AT ALL. Other minor stuff will be the headlights and trim and such.
~~~ 99 Contour SE ATX 2.0 ~~~
~~~ 98 Mystique GS ATX 2.0 ~~~
~~~ 94 Civic DX HB MTX 1.5 ~~~
~~~ 91 Toyota MR2 MTX 2.2 ~~~
Posts: 1,159 |
most supports are welded in for strength...im not sure about ours exactly. youre type and model year would help ppl a bit too
05 Chevy Colorado z71 4x4 *for sale*
97 Honda Accord 4door track whore *12.9 N/A* (blown and wrecked)
97 Honda Accord 4 door
03 Eclipse GS
Posts: 101 |
My bad, this is a 99 Contour SE Zetec.
I'm pretty confident I can get all but the rad support off, that's where the problem is. I've seen some people do a front end swap, but no mention on how they got the parts off.
Posts: 5,143 |
Originally posted by JeSuS iS LoRD: most supports are welded in for strength...im not sure about ours exactly. youre type and model year would help ppl a bit too
Worst comes to worst, you could get some JB weld and redo the supports.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 101 |
JB Weld? How is that going to hold the support on properly? I though of using grade 8 hardware to replace the weld spots once removed. Won't that work?
Posts: 2,838 |
It sounds like it's only a small hit . Most likely worth fixing up yourself . You could go to a junkyard & look for the parts you need , and take the opportunity to "learn" how to replace the parts while you're removing them from the donor car . Go for it !
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
Posts: 185 |
i have worked in a body shop as a helper for about a year now and every one that i have seen. is spot welded in
Mystique 98 ls T-red
MTX
B&G springs
Turbendz y-pipe (running test pipe)
Trubendz cat back with flowmaster muffler
Costume intake with K&N filter
B&M shifter
Magstar wires
Posts: 101 |
Well, from all the replies I see that it is welded on, and Avey had written to me saying I can drill out the welds. So once I drill out the welds and remove the rad support, can I place the new one in using grade 8 hardware?
I'd go to a u-pull-it salvage yard and pull everything except the rad support which I cannot do myself without my electric drill on site. The rad support I can buy for less then $100.
Posts: 2,659 |
First hand good thing to hear your wife is okay. And it doesnt sound to bad of a car crash. You should post pics so we can "really" see the damage. Good luck on the fix!
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 101 |
Thanks, I appreciate that. The crash does not seem too bad until you pop the hood. I took pictures but got no place to host them. Anyone?
