Posts: 1,475 |
Once every 2 months? For a tear-down that's excessive. Once a year is enough.
I've done this 3 times now and my preferred method is:
UIM - leave the TB on, unbolt everything else and stuff rags into the open holes. Turn upside down and pour liquid berrymans into the ports. Let it sit for awhile, then Swish/shake around inside the UIM for awhile, then open the TB to let the dirty gunk pour out. Repeat several times. Clean the edges of the ports with a rag soaked in berrymans. Liquid berrymans PO3WN's your carbon-caked UIM!
LIM - a couple spray cans of berrymans with a rag and wire brush will do the trick
Intake Ports - I found a steel wire brush at Home Depot that fits almost perfrectly into the ports, and can be pushed right down to the valves. I used it to clean up the ports w/o spraying any berrymans into the engine. Restarting was much easier too w/o all of the junk and crud from the manifolds filtering down into the cylinders.
Posts: 4,292 |
Originally posted by akrump47: Once every 2 months? For a tear-down that's excessive. Once a year is enough.
...you dont have to replace the gaskets everytime for one, and for something that takes about the same time to change your oil,its not really that excessive...i'm able to tear it down in less than 10 minutes
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 1,047 |
I dread to see what mine will look like with almost 300 000km on it. *shudder*
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's
'89 Mazda B2200 - Under Construction
Posts: 1,017 |
Originally posted by R6j6B: Originally posted by platinum_drew: I might clean it more often if the required materials didn't rack up at $200+
www.teamfordparts.com the cost is way lower than $200 + about $25 in cleanong agents .
I'm not even gonna click that link to learn, just as I'm sure the UIM/LIM gaskets alone cost more than 25 bucks
1995 SE
2.5L V6/MTX
187k
