Thought I would put in an update, car should be out of the shop by this weekend, but still needs a few things done like 65mm throttle install, fuel pump change, chip install.
head with exhaust manifold
Heres a closer look at one of the cams
Drivers side, not much there but its so clean right now
The adjustable cam gears weren't in stock when I tried to purchase them before the car went into the shop, so I'll have them installed later
Intake side; the Focus intake manifold will have to be used along with a Focus fuel rail. I used a BDL rail with 30# injectors. The rail will require a adjustable regulator 2bolt style, for the fuel return system to work, and longer fuel lines will have to be used since the regulator sits on the pasenger side and not the drivers side fo the fuel rail.
I think this is the EGR valve
(I could be wrong), or whatever it is called will have to be modified. On the Focus intake its horizontal and on the Tour intake its vertical, so I'm having them cut swaped out and rewelded on. Hopefully it comes out good, I'll get picks of it once its finished. You can see the rail and injectors in there also.
Focus valve on right, Contour valve on left
