Posts: 58 |
Alright, its been, y'know snowing here in Ohio these past two days. And latley when I go to do a cold start it takes 4 turn overs to fire. I know it may be common in the cold, I just wanna check.
Posts: 5,345 |
Yep, our Contours hate the cold. If you can, try plugging in an engine block heater.
1996 V6 ATX 96K miles
Posts: 58 |
Alright, that would work for home, does it need a standard 120 volt connection?
Posts: 1,047 |
i have always had cold start problem with all 3 of mine. the two I have now have block heaters,so I'm gonna try them out this winter and see how it goes. My Duratec needs a new starter though,whenever it's cold and I start he car,the starter keeps spinning for up to 30 sec after the engine is running.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's
'89 Mazda B2200 - Under Construction
Posts: 140 |
I had the same problem about a month ago. Make sure the IAC valve is clean.
The Contour doesn't like cold weather.
00 CSVT Black/Midnight Blue
2.5L DOHC Duratec V6, 200HP, MTX-75
MODs: K&N Filter, SVT ovals, Autometer gauges, PIAA 510's, Alpine S-type FE/Pioneer R, Pioneer Premier Series reciever
#603 of 2150
92 Cavalier 1.8L I4 (Beater)
